Question about Jet 414459 HVBS - 7MW Horizontal/Vertical Bandsaw
I have a stock #414457 Jet bandsaw and when I try to tighten up the vise, it jumps back before it's tight. I think the problem is with the
  • Jack Faire Nov 09, 2012
    What seems to be the problem of your Jet Bandsaw?
    Sergeant:
  • 468 Answers
If you need parts for your band saw, you can visit www.bandsawparts.com . They offer cheap aftermarket parts of Jet band saws.
Posted on Feb 08, 2013
2 Suggested Answers
SOURCE: jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
Posted on Aug 10, 2009
Replace guide bearings on jwbs-18 saw
" That one will be a press fit onto that eccentric shaft. Small bearings like that are easy to drive off with a suitable punch or mandrel. Simply stand it up in the jaws of a vise so the jaw edges contact the outer rim of the bearing and use a hammer to drive it out. Put a washer or similar bit of metal between the shaft end and the punch to protect the face."
Make sure before you put the new bearing on that the shaft is clean and smooth.
Nov 07, 2013 | Jet Machinery Jet Equipment 708750B...
Grizzly g4030 bandsaw vise adjustments
Is that an old saw ? Check your manual or call a tech support.
Jul 03, 2013 | Saws
Grizzly bandsaw repair parts
The only suggestion I have is call the manufacturer of the saw . If you want to read some facts about band saw, visit this blogging site.
Jul 03, 2013 | Saws
Bandsaw blade tension
It must be a worn part. It simply needs replacement. Try calling first your Jet or consult your manual.
Jun 23, 2013 | Jet 707200 10Inch Band Saw
TAPPET ADJUST 455 PONTIAC
Simply reinstall the factory Pontiac studs, assemble valvetrain, and tighten down lock nuts until they're tight. You cannot over-tighten them, unless of course you break the studs off trying to get em bulls-*** tight. New lock nuts are a must if theyve been off more than once.
Be advised, that camshaft will turn a stock 400 into a bit of a dog down low. Factory 400's had around 8:1 compression and were designed to be a 'torque engine', not a top end screamer.
It'll make more power up top, but stock valve springs wont be too happy with that much lift and 5000r's is just about the limit on these long-stroke motors.
Jul 26, 2012 | Cars & Trucks
I have a 12inch craftsman bandsaw/sander, model number is 113 24200. i don't have a manuel and the blade keeps jumping off. I need a skematic of the saw so I can tell if something is missing. The...
There are many craftsman manuals available online at the sears site at http://www.managemylife.com/mmh/owner_manuals. Try this link to download the one you're looking for.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 31, 2011 | Craftsman Saws
The plate covering the chain sprocket will not go back on. The breaking device is to tight to go over the clutch drive. I don't want to force the plate on. Please reply
Hi, you have accidently activated the chainbrake while the cover was off. Grab the cover in a vise where the bar nuts tighten up to and pull the chainbrake lever back towards where the handle bar would normally be. It will click back, then you can fit it. Hope this helps, regards Phil.
Jul 26, 2011 | Husqvarna Garden
I took the stock air filter off my 2000 Suzuki Katana 600 and put a K&N air filter in it, when i accelerate it stalls out a bit before kicking up to speed. a slight lag then go.
Changing to a K&N air filter changes the air/fuel mixture for your bike, and you're probably hitting an overly lean spot before things start to even out. For bikes still running carburetors, which I think you have, you can compensate for this by changing to a slightly larger idle jet. Your main jet is probably fine (it's kicking in after the lag); it's the crossover from idle to main jet that's causing the flat spot.
Talk to your dealership parts counter to get recommendations about jet settings. They may suggest, for example, to keep your existing idle jet and go with a different main jet. Expect to try a couple different setups to find one that works best for your bike and your riding style. I would highly recommend keeping your original jets, though, in case you ever go back to the stock air box.
May 09, 2011 | 2000 Suzuki GSX 600 F (Katana)
Jet model jwbs-14cs bandsaw purchased used, need manual
Dec 28, 2008 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Where can I downlaod a owners manual for the jet 1-3/4-18" bandsaw today
I went to Jet Tools.com and typed in your model number but it came back with no results. You might try and check it again and contact them for further info. Hope this helps. Dave
Nov 09, 2008 | Jet 1 - 3/4HP - 18" Bandsaw - 710750
Jet 414459 HVBS - 7MW Horizontal/Vertical Bandsaw Logo
114 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
