Question about Yamaha Audio Players & Recorders
How to reset yamaha rx-v595 - Yamaha Audio Players & Recorders
4 Suggested Answers
SOURCE: Reciever won't switch back on
you need to take it to the nearest yamaha service centre. Unit could have had a surge or blown a fuse.
Posted on May 26, 2008
  • 87 Answers
SOURCE: The sound will suddenly go off on my Yamaha
This is a classic over heating problem. There are 2 likely causes - hope for the first.
1. The speakers or wiring have a problem and draw too much current from the receiver. Carefully check your wiring. If it looks OK, leave both speakers disconnected and turn the volume control all the way down. Power the unit up. If it stays running, then try one speaker then the other (at low volumes to avoid damage) and see if one makes it shut down. If it does not stay running then see #2.
2. The power amp circuitry of the receiver has an issue causing it to overheat or the overtemp circuit is faulty and it thinks its overheating. Either way, this one needs professional help.
Good luck
Posted on Oct 23, 2010
gopakumarg43
  • 75417 Answers
SOURCE: Hello I have a Yamaha
Hello
You can connect DVD/LD/Blu-Ray players' outputs to your Yamaha RX-v595. OK.
Posted on Jul 11, 2011
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Smart TV but reveiver does not have HD plug ins
I would input everything directly to the tv via hdmi, then take the optical audio output from the tv back to the receiver.
Jan 04, 2013 | Yamaha RX-V595 Receiver
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Problem with potentiometer Does anybody know where is possible to buy volume- potentiometer for Yamaha RX-V595RDS? When I turn receiver on sometimes one output chanel (speaker) is silent till I turn...
A little more triage would be in order before you take a knife to it.
Turn the volue to something in the middle.
If it's only an analog source doing it I would suspect a bad switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 21, 2011 | Yamaha RX-V595 Receiver
LOSS OF BASS IS THERE A FUSE IN THE RECEIVER FOR THIS
Jeff, The speaker it self may be fused. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha V905 Owner Manual
YAMAHA RX V595 V905 RX V595RDS Service Manual free download schematics...
Feb 27, 2011 | Yamaha R-V905 Receiver
My yamaha keeps turning off as soon as i turn it on...
Buy yourself a 120mm 12volt computer case fan and a 12volt power pack. Mount the fan with some double sided tape to the grill on top of your AVR. Have the fan mounted so it draws air out of the amp and turn it on when you know you are going to crank up the volume. Try and buy a fan with the lowest noise level so it isn't annoying
Dec 10, 2010 | Yamaha RX-V595 Receiver
The sound will suddenly go off on my Yamaha RX-V595 receiver. I can turb it back on and it will play for awhile and then turn off again
Good luck
Oct 23, 2010 | Yamaha RX-V595 Receiver
Our unit turned off suddenly one day, and now you
If it trips almost instantly then you have a serious power supply rail problem rather than just a channel down. You need a Yamaha specialist to look at it, there aren't any fuses for that.
Oct 24, 2009 | Yamaha RX-V595 Receiver
Mar 25, 2008 | Yamaha RX-V595A Receiver
206 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
