Question about Samsung DVD-V4600 DVD Player/VCR
No disc spinning when loading dvd disc, disc does not start spinning
If i help spin the disc then it will go and play
SOURCE: DVD player says "no disc"
two DVD player with same problem. I think they are disposable. :(
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: DVD 330
I know the slightest bit of dust either on the disk or in the player causes this in mine. Usually I can simply wipe the disk with a soft cloth when mine does it and it works fine.
Posted on Jul 05, 2008
SOURCE: DVD-VR330
hI..
Had same problem with mine, got a used vr357 from ebay swapped loaders. vr330 works fine now; (bad loader)
Posted on Jul 27, 2008
SOURCE: When putting a disc in
You have gone through the hazzle to see if the wires/cables are all where they should be.
pushed "eject" once or twice. If nothing happens at this stage, I often find it helpful to cut off the electricity for up to five minutes. Then start all over again similar to restarting the computer.
Open for the disc to be put in and push "play".
best of luck
Kolbrun
Posted on Jun 10, 2011
GodfatherCZ
  • 37 Answers
SOURCE: samsung htz310-will not play dvd,sounds
How many DVD did you tried?
Posted on Jun 11, 2011
Disc
Pull the power plug, let it stop spinning, and then re plug it in. See if that helps eject it.
Sep 03, 2014 | LG RHT497H Digital TV Recorder with 160GB...
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Jul 13, 2007 | Sanyo DWM-3500 System
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Playing dvd's
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more. P.S. please use line breaks between paragraphs and one "dot" at the end of a sentence is enough.
Nov 30, 2005 | JVC TH-A9 System
Samsung DVD-V4600 DVD Player/VCR Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
