Question about Plumbing
Where is the washer on a mico model 7705 kitchen faucet
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Posted on Dec 05, 2008
  • 68 Answers
SOURCE: Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Posted on Dec 09, 2008
  • 6 Answers
SOURCE: I have a Mico 7777 Kitchen faucet that was
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them 1.it will help go on easier 2.it will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Posted on Apr 08, 2009
  • 2692 Answers
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Posted on Apr 25, 2009
  • 409 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Posted on Mar 11, 2010
Where can I buy cartridges for my Mico kitchen faucet?
try plumber supplies wholesalers where the plumbers get their spares from
not a hardware or supermarket shop
Dec 24, 2017 | Plumbing
I have a moen kitchen faucet with spray (high spicket) and a leak is developing at the bottom of the spicket. i may need a washer, but i do not have a diagram. i believe the model number is kvn01-01. thank...
If no satisfaction from Moen, hardware stores usually have "O" ring replacement kits by faucet type, and it will likely have the one you need in it.
Usually only a few dollars.
Jan 04, 2010 | Moen 87530 Touch Control Single Handle...
Our jameco kitchen faucet has no water pressure. also we have a slow leak on the cold water side. The faucet is only 3 years old. we took the cold side apart and there is no washers, only an o ring that...
Sounds like you may need to replace the cartridge if you have one of the late model single control models. You may get a clue as to how your faucet might be put together by finding a similar faucet on the Moen web site, and looking at their exploded parts diagram. (They are good about posting information; although some say their products are not so good; I really don't know personally)
Dec 14, 2009 | Delta 2402 Classic Single Handle Kitchen...
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
Apr 07, 2009 | Plumbing
Broken thumb lever to a kitchen faucet side spray
Unless you have a super duper fancy faucet, all spray head for kitchen faucets are standard, and can be picked up at any hardware store, home depot, lowes or plumbing supply.
The easiest method of replacement is to screw off the handle, and leave the old hose intact. On the hose you will find two black washers. one fat and one thin. Take note which one comes off first and replace in that order. Pull back the screw housing and you will see the white plastic tube on the end of the spray hose has a locking ring nestled in a groove. Remove it. Now you can remove the old screw housing and put the new one on. After putting the handle screw housing on the hose, install the lock ring back into the groove., put washers back on in correct order, and screw your new spray head on. Good luck!
Apr 08, 2017 | Plumbing
Phil
Oct 17, 2008 | Delta 2402 Classic Single Handle Kitchen...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Plumbing Logo
150 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
