Question about Citrix Nuance Dragon NaturallySpeaking Professional 10 Upgrade Version for PC
Lost my dragon naturally disk - Citrix Nuance Dragon NaturallySpeaking Professional 10 Upgrade Version for PC
Lost serial number
If is is installed on your PC you can find its serial by installing Belarc Advisor - this is a free application for PC inventory on hardware and software installed on your PC
Aug 08, 2014 | NRS Nuance Dragon Naturally Speaking 10...
DRAGON NATURALLY SPEAKING, WHEN i CLICK ON ICON I GET ERROR "ACTXPRXY.DLL DID NOT REGISTER ITSELF" CAN I DOWNLOAD THE FILE ?
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it http://youtu.be/rNDBRYdDXqo ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website http://support.nuance.com/compatibility/ . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
May 07, 2014 | Computers & Internet
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Aug 29, 2012 | Nuance Dragon Naturally Speaking 11.5...
Dragon Naturaly speaking XP editions not finding audio and video cards
and we can assume your computer is running xp correct? If not, then you'll need the updated Dragon, naturally speaking
May 29, 2012 | Dragon Systems Nuance Dragon...
Serial Number
Hello
i had brought this software 1 mouth ago dragon natually speaking 10. I have lost the serial number to activate it.the store i purchased it from will not refund it whats so ever. You are my next best hope.
Thank you
Stacy Carnley
Sep 09, 2010 | Dmm Nuance Dragon Naturally Speaking 10...
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Jun 05, 2010 | NRS Nuance Dragon Naturally Speaking 10...
I dont have dragon naturallyspeaking serial no.
The serial number can be found on the sticker on the back of the white envelope of the dragon disc.
Mar 14, 2010 | Dmm Nuance Dragon Naturally Speaking 10...
Citrix Nuance Dragon NaturallySpeaking Professional 10 Upgrade Version for PC  Logo
Top Citrix Computers & Internet Experts
xxxxxx xxx
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
