Edenpure error codes
5 beep error code
    Habit-Forming:
    Scholar:
  • 111 Answers
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade maybe and if need more visit us and a live tech can give you free advice 24/7.
http://www.ezsystemrepairs.com/
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Nov 09, 2012
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 09, 2013 | EDENPURE USA1000 Infrared Heater
Dell inspiron m 5030 7 beep code
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Nov 10, 2012 | Dell Computers & Internet
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    I am getting three short beeps while booting
    The beep codes below may help you identify the possible computer problems. However,
    they are only for reference purposes. The situations might differ from case to case.
    gAMI BIOS Beep Codes
    *Computer gives 1 short beep when system boots successfully.
    *Except for beep code 8, these codes are always fatal.
    1 beep Refresh failure
    2 beeps Parity error
    3 beeps Base 64K memory failure
    4 beeps Timer not operational
    5 beeps Processor error
    6 beeps 8042 - gate A20 failure
    7 beeps Processor exception interrupt error
    8 beeps Display memory read/write failure
    9 beeps ROM checksum error
    10 beeps CMOS shutdown register read/write error
    11 beeps Cache memory bad
    g AWARD BIOS Beep Codes
    1 short: System boots successfully
    2 short: CMOS setting error
    1 long 1 short: DRAM or M/B error
    1 long 2 short: Monitor or display card error
    1 long 3 short: Keyboard error
    1 long 9 short: BIOS ROM error
    Continuous long beeps: DRAM error
    Continuous short beeps: Power error
    Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
    At POST I get 2 short beeps
    it depends on the bios chip maker Here's some other beep codes:
    for Award and Phoenix BIOS:
    1 short beep: Normal
    2 short beeps: CMOS error
    1 long and 1 short beep: DRAM error
    1 long and 2 short beeps: Video card error
    1 long and 3 short beeps: Keyboard error
    1 long and 9 short beeps: ROM error
    Long continuous beeps: DRAM not installed correctly
    Short continuous beeps: Bad power supply
    AMI BIOS:
    1 short beep: DRAM flash error
    2 short beeps: DRAM ECC check error
    3 short beeps: DRAM detect error
    5 short beeps: CPU error
    6 short beeps: Keyboard error
    8 short beeps: Video card error
    1 long and 3 short beeps: Bad DRAM
    1 long and 8 short beeps: Video card error
    Invoking Beep Codes
    If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
    BIOS Beep Codes
    Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
    Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
    AMI BIOS
    # of Beeps Error Description
    1 Refresh Failure The memory refresh Circuitry is faulty
    2 Parity Error Parity error in the Base (1st 64K) of memory
    3 64K Base Memory Error Memory error in the base memory (1st 64K)
    4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
    5 Processor Error CPU error
    6 8042 Gate A20 Failure Unable to switch to protected mode
    7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
    8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
    9 ROM checksum error The ROM checksum does not match that of the BIOS
    10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
    11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
    With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
    Always check for loose components before sending the board back as this is the main cause of errors on the POST.
    Award BIOS
    Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
    The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
    IBM BIOS
    The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
    Beep Code Error
    1 Short Beep Normal POST, System booted OK
    2 Short Beeps POST Error - Code on Display
    No Beep Power supply or Motherboard error
    Continuous Beep Power supply or Motherboard error
    Repeating short beeps Power supply or Motherboard error
    1 short, 1 long beep System board error
    1 long, 2 short beeps Display adapter error (MDA/CGA)
    1 long, 3 short beeps Display adapter error (EGA/VGA)
    3 long beeps 3270 keyboard card
    Phoenix BIOS
    The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
    Phoenix BIOS Post Codes
    System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
    Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    Computers & Internet Logo
    319 people viewed this question
    David Payne
    David Payne
