51' widescreen hdtv ptv monitor lightbulb
Need a light bulb
  • 8,617 Answers
Www.tvrepairworld.com should be able to provide the bulb for any model television and provide free installation assistance also
Posted on Nov 09, 2012
My light just burnt iut onmy kenmore sewing machine and now it wont work
You need to replace the lightbulb. You may need to remove the cover over the lightbulb off in order to remove the bulb. Take the bulb to the local sewing machine repair shop or order a replacement online.
FWIW, you may want to consider an LED bulb. They are much brighter and do not get hot like the standard bulbs.
Mar 15, 2017 | Kenmore Sewing Machines
Where do I buy a lightbulb for the Nostalgia model?
It is just a small spot light. Take the old bulb to your local hardware store. They will have a replacement.
Mar 08, 2015 | Nostalgia Electrics Helman Group CCP-509...
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    Screen goes black after 2 sec
    The lightbulb high voltage power supply is detecting problem with the low voltage power supply or with one of the light bulbs and shutdowns in emergency. Open the monitor and check for inflated capacitors. Replace all capacitors even if only few are inflated. Light bulbs require further testing empowering them one by one with external high voltage por supply and their replacement is not easy. Have to open the LCD and then it's hard to clean the layers from the dust resulting bad spots on the image. Be careful and good luck.
    Apr 08, 2012 | LG Flatron Computers & Internet
    I HAVE A 56"
    Thats called the front keyboard its available from www.tvrepairworld.com under RCA circuit boards.
    Aug 25, 2011 | RCA HD56W66 56" HDTV
    What kind of lightbulb goes into the popcorn cart model # CCP-509 and where can I purchase the lightbulb
    Your Use Manual can be found here.
    On page 4 of the pdf it indicates that an E27 40 Watt light bulb is used.
    You should be able to purchase a replacement bulb in any lighting department that stocks a full range of light bulbs including appliance bulbs; this would more commonly be referred to as an oven light bulb.
    Jan 29, 2011 | Nostalgia Electrics CCP-509 Popcorn Maker
    Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
    Your power/inverter board is in need of an overhaul.
    The capacitors are failing and possibly a transistor.
    If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
    If you take it apart and send me a picture, I may be able to tell by looking at it.
    I repair these boards on ebay
    bammbammfran
    Nov 05, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
    Hitachi ultravision digital widescreen
    my tv has a magenta pink and green stripe accross the top of screen...is this a bulb problem
    Nov 01, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
    Televison & Video Logo
    15 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
