Question about Intel D845PT (KD845PTPAK10) Motherboard
Bios hangs I have a computer with an Intel D845PT motherbaord. When I boot the computer hangs on the OEM splash screen. I reboot and try to get into the bios by hiting F1 but it hangs on "Entering Setup." Any tips will be greatly appreciated. David
    Sergeant:
  • 367 Answers
Reseat all cards in system, including the RAM. If it still does not boot try removing one stick of ram at a time to see if it boots. As well as removing extra cards.
Posted on Jan 05, 2009
HOW to install windows xp on intel dh61ho motherboad
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61HO
In general, what you'll need to do is:
  • Turn off your computer.
  • Power on again
  • When you see the splash screen or BIOS menu (and before Windows starts to load), hit the Delete key.
This will typically either get you into a boot device menu or the BIOS settings where you should be able to select the device you want to boot from to adjust the boot order. In other words, your computer may normally try to boot first from the hard drive drive.But now you have to select to boot from the dvd drive. Save the changes, and then boot your computer again, this time without hitting any button and lay the windows disk in the dvd drive. If all goes according to plan, you should soon see a "Windows loading" message on your screen and press any key to install windows.You can follow the on-screen instructions to install Windows on your computer.
You also need to make a full format of the harddrive, and reboot again.
Look also in the manual how to setup the bios.
Here is some youtube video that shows how:
http://www.youtube.com/results?search_query=how+to+install+windows+xp&oq=HOW+to+install+windows+xp&gs_l=youtube.1.0.0l10.1637.1637.0.3243.1.1.0.0.0.0.122.122.0j1.1.0...0.0...1ac.2.LqJatFrFwa4
When the installation is done, you have to install all the driver for the mainboard.Graphic,sound,chipset etc.
Good luck
Jan 28, 2013 | Intel Desktop Board DH61HO - Classic...
Gateway splash screen thats all I get
Try hitting the delete key over and over at boot up. If you can get to BIOS, you can disable the splash screen, and also make sure that the boot order is correct. Try to put your hard drive as first boot priority. Also, remove any CD's in the drives.
Good Luck.
www.cobaltflorida.com
Jan 20, 2010 | Gateway GT5242E PC Desktop
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
How can I prevent my E Machines logo from loading everytime I start my computer. I have Windows XP.
Press and hold the F2, F12, or F8 function key (one of the three at a time) after jhearing a single beep following a restart. One key (usually F2) will allow you to change the BIOS settings. (If the computer boots normally, restart it again and try the next function key.)
BE CAREFUL. Don't change anything you are not sure of because doing so can make your computer inoperable!
You will eventually get to the BIOS settup utility. You will have to use the keyboard to navigate to the setting that disables the splash screen. (You may have to enable something like "detailed boot report" or "OEM settings", depending on the computer.)
My American Megatrends (AMI) BIOS has a "BOOT" section that contains a "Full Screen Logo" setting. I "Disabled" it to do what you want to.
Incidentally, the splash screen doesn't really slow the boot process much, since you are simply substituting a static picture for the BIOS boot information.
Aug 25, 2009 | eMachines EL1210-11 PC Desktop
Gigabyte MB Bios Freeze
It could be any number of things. Yes, it could be motherboard but it could be any piece of hardware connected to it. Detach everything except CPU, memory, cpu fan, and video (if it doesn't have onboard video). And reboot. If it does the same thing then we've narrowed it down. If it gets past the screen and says can't find bootable device (or something simillar), then start adding on one device at a time until you find the culprit that locks it up at the splash screen. Experience tells me possibly CD drive or hard drive. Good luck!
May 25, 2009 | Intel Motherboard
Intel Desktop Board D945GNTLKR did not boot
Try choosing the 'Exit Without Saving' option in the BIOS menu. If this kicks you to the boot media search, then 99.99% the BIOS is corupt. If not, try to replace the CPU cooler (don't forget to apply the thermal grease).
Mar 15, 2009 | Intel Computers & Internet
Need original bios
you should enter your motherboard manufacture website and dawanload new version
Jan 12, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Windows XP Pro hangs on reboot after installation
Try removing your AGP card and enabling the onboard graphics again. It is possible your Radeon is a 3.3v, but this board only supports 1.5v cards. Take a look at the manual at ftp://download.intel.com/support/motherboards/desktop/D845GERG2/BV2RG2_English.pdf
Dec 29, 2008 | Intel 845GE Motherboard
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
Intel D845PT (KD845PTPAK10) Motherboard Logo
238 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
