Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Just got a mitsubishi projection tv from a friend and ever since I hooked it up at my house it'll start up fine but whenever I hook up inputs (dvd player, games, dishtv etc.) they'll run for about a minute and then the tv shuts off.
  • internet_g0d Jan 05, 2009
    Unfortunately I don't think that would adequately explain the problem. The tv works perfectly fine up until inputs are plugged in. I'll turn on the tv and be able to get a blue screen or a static screen without any problems and I can change around setting in the menu. When I plug in a dvd player or game system though, it'll still work but if I switch to the input that I'm using it'll change and show the movie or game working fine but only for a few seconds before the tv turns off automatically. It seems that active inputs cause the tv to automatically shut down but there's no apparent reason or sign of what triggers the tv to shut off.
  • Mitsubishi Master
  • 5,568 Answers
I am fairly sure that this set has a cooling fan to prevent the meltdown of anything since there are parts that run very hot.
Listen at the rear of the set for any sound of a fan running.  If you don't hear one or is seems very quiet, the fan may have or may be failing and a thermal sensor is used to detect an overheating occuring. This would explain the shutdown of the set after a brief period.
If you find a failed fan, this may be a relatively easy DIY repair.
Posted on Jan 05, 2009
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
What channel for dvd
What input do you have your DVD hooked into? That would be the input that you want the TV on.
Mar 20, 2013 | Mitsubishi VS-50603 50" Rear Projection...
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
DO YOU WANT THIS INFORMATION?
A VERY HELPFUL RATING IN RESPONSE TO THIS SOLUTION WILL TELL YOU HOW TO GET INTO THE OPTION MENU.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
Jan 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ws-55511 component inputs will not work
you have to hook up the HDTV receiver to the INP (or what ever the initials are) input to get HD
Oct 18, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
