Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Download needed no *go variable - VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
  • VeriFone Expert
  • 113 Answers
'No *GO Variable' indicates that the terminal was unable to locate a valid Go Variable used to initialize the terminal.
Use the following to guide you through resolving this problem. Terminal Response Probable Cause Solution No *GO
Variable The terminal is not loaded with the VMAC (Verix Multi App Conductor) program used to allow the terminal to access multiple applications (File Groups). Download VMAC into the terminal. The download installed into the terminal is corrupted. Re-download the terminal. The terminal has not been downloaded. Download the terminal. The download did not authenticate correctly. Re-download the terminal. The download did not unzip into the correct location, therefore cannot be accessed. Re-download the terminal, if this is unsuccessful, verify where the file is being unzipped to.
I hope this help if not them call 775 - 358 - 2922 : - )
Posted on Dec 05, 2012
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
You will need to call your merchant services for a download, you have lost programming
Posted on Jan 02, 2015
Manual for Breville BGR200XL Variable Temperature Panini Grill
Hello Kevin, I have a link to the manual online. It can be downloaded in pdf format or you may view online. Here is your link.
http://www.breville.ca/media/mediaappearance/4528/BGR200XL_IB_B13_FA_LowRes.pdf
May 15, 2015 | Breville BGR200XL Variable Temperature...
I can't get my scanner hooked up
Are you getting an error message? It could be your path EV. Try this
Look in C:\Windows\twain_32 and there should one other folder in there. In my case it was named CNQ4803.This is the path that is needed to be added into the PATH environment variable.
C:\Windows\twain_32\CNQ4803
Now, follow these instructions to get to the dialog to modify the PATH environment variable.Control Panel > System > and then choose Advanced System Settings in the left hand column.This will bring up the System Properties dialog (it should already be on the Advanced tab).At the bottom of this dialog is an Environment Variables button. Clicking this button will bring up the Environment Variables dialog. In the bottom panel, scroll until you find the variable named Path. Select this one and then hit the Edit... button to bring up the Edit System Variable dialog.
In the Variable value text box, scroll all the way to the right and then add in the path C:\Windows\twain_32\CNQ4803 that was determined earlier. Make sure to separate this value with a preceding semi-colon. And also be careful not to make any other changes to this value.
Now OK your way out of all of the dialogs and CanoScan Toolbox should now work as expected.
Nov 10, 2014 | Office Equipment & Supplies
Problems changing variables on windows 7 for Java jdk1.7.0. I have no path variable any ideas thankyou
If your trying to add javac.exe to your path variable do the following
  • Right Click Computer
  • Select Properties
  • On the left select Advanced System Settings
  • Select Environment Variables
  • Under System Variables scroll down to Path
  • Append the path and exe to the Path variable
If memory serves javac.exe is located in C:\Windows\System32 so append ;C:\Windows\System32\javac.exe
Comment if you need more help
Sep 13, 2011 | Sun Computers & Internet
Java not loading it is saying not found
You need to have downloaded the latest Java Development Kit: http://www.oracle.com/technetwork/java/javase/downloads/jdk-6u25-download-346242.html
Then once its installed open the command line (type cmd into the search bar and hit enter). Type java and hit enter into the command line and it should come up with commands to do regarding Java. If so then it has found it.
Uninstall and reinstall if you have already done this as sometimes the 'CLASSPATH' becomes faulty. If it still didn't work right-click My Computer -> Properties -> Advanced System Settings -> Environment Variables and look for a variable called 'CLASSPATH'. If it isn't there you need to add a new one and point it to where you installed Java.
May 07, 2011 | Sun Computers & Internet
Verifne vx 510 screen says downloaded needed no* go varibale use phone line to dial out
A response of 'No *GO Variable' indicates that the terminal was unable to locate a valid Go Variable used to initialize the terminal.
The download installed into the terminal is corrupted. Re-download the terminal. The terminal has not been downloaded. Download the terminal. The download did not authenticate correctly. Re-download the terminal. The download did not unzip into the correct location, therefore cannot be accessed. Re-download the terminal, if this is unsuccessful, verify where the file is being unzipped to. :- )
Dec 17, 2010 | VeriFone Omni 3700
Where i can get software for C Programing language and what is the software name...........?
STEP 1 : Download the Borland Compiler
https://downloads.embarcadero.com/item/24778
STEP2 : Run the setup program
By default, it should install everything to C:\Borland\BCC55
STEP 3 : Add the /bin directory to the system PATH
>C:\Borland\BCC55\bin\bcc32 OR >c32
After the setup program is run (step 2), a whole bunch of executable programs are placed in a new directory : C:\Borland\BCC55\Bin. This step makes it possible for the Operating System (Windows) to find these new executables by name. If you don't do this, then you will need to specify the full path to bcc32 every time you use it.
To do this on Windows XP
Bring up the Environmental Variables :
•Right Click "My Computer" ( Depending on how your system is set-up, "My Computer" is either on your Desktop or in your Start Menu )
•Select "Properties"
•Activate the "Advanced" Tab
•Click the "Environmental Variables" Button
Append ";C:\Borland\BCC44\bin" to the PATH variable (figure 3-2)
•Select the PATH variable under User Variables
Note: The PATH variable may appear under both System Variables and User Variables. This How-To changes the User Variable.
•Click the EDIT button below the list
•In the "Edit User Variable" box that pops up, move the cursor to the end of the Variable Value field
•Add a semi-colon ";" to the end of the current value
Note: If the value is empty, then you do not need to add a semi-colon
•Add the path "C:\Borland\BCC55\bin" after the semi-colon
•"OK" your way out of the dialogs
STEP 4 : Set up some configuration files
you should create a configuration file for the bcc32 program that tells it where to find its libraries and include files.
•The file should be named bcc32.cfg
•It should be placed in the same bin directory where bcc32.exe is located
(C:\Borland\BCC55\Bin)
•The contents of the file are the command line options for bcc32 stating the location of include files and libraries:
-I"C:\Borland\BCC55\Include"
-L"C:\Borland\BCC55\Lib"
Regards,
Soul_srch007
Dec 06, 2009 | Microsoft Windows XP Professional
How do you restore a TI-89 Titanium clac
Perhaps one of the following sources will be helpful:
To reset the TI-89 family, TI-92 family and Voyage 200 graphing calculators, press [2nd] [6] (reads MEM over the key). The [F1] menu appears and contains the following options:
  • All RAM - Clears all variables and programs from RAM only. This will not delete items from Archive or Apps.
  • Defaults - Does not clear any files from the calculator. Instead, this option resets the calculator settings to default, including the Mode, Graph Format, Table Setup, and other settings.
  • Vars - Clears all variables from Archive (Flash ROM). This option will NOT delete Apps or variables stored in RAM memory.
  • Apps - Clears all Apps from Archive. This will not delete any variables.
  • Both - Will clear all Apps and Variables from Archive. This will not delete any Variables from RAM.
  • All Memory - Clears everything from RAM and Archive, leaving only the Calculator OS and its components.
For example, I think you will want to follow the last step above... which would be to press [2nd] [6] [F1] [1] [1] [ENTER] [ENTER].
Also, if you are looking to clear all the RAM in another way I would take a look at the guidebook, which is downloadable from the following site in PDF format.
http://education.ti.com/downloads/guidebooks/graphing/89ti/TI89TitaniumGuidebook_Part2_EN.pdf
Take a look at page 951 and 952 for another way to clear the RAM
Jan 29, 2009 | Texas Instruments TI-89 Calculator
I need to add variables on my calculator
To save enter the number you want to save then press [STO] and the variable you want to save to.
And to use the variable you need to recall it by [RCL] button and then the variable you want to recall.
Rate me, thanks.
Dec 03, 2008 | Texas Instruments TI-34II Explorer Plus...
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
3,671 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
