Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Cannot get or detect wireless internet on daughetrs new toshiba laptop, my own connecting fine
  • Ved Pradhan May 11, 2010
    hi...
    we need to know what operating system is installed in the computer and the model no for the computer
    let us know that....one thing what you can check is the wireless radio,whether it is on or off,there will be a light on the laptop itself which shows whether the radio is on or off as well as there will be a switch to turn it on incase if the light is off.
    For most Toshiba notebooks,
    this switch is located on the front left side of the notebook. Consult your user
    manual for more information about where the switch is on your particular system.
    below is the picture of a wireless switch located in toshiba laptops..
    vedhick...
  • Chris Hingee
    Chris Hingee May 11, 2010
    Has the drivers for the wireless card been installed, if has it been configured, if so does it match the wireless router's configuration?
    What are the wireless router's configuration, does it have any encryption setup etc.?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try for your NETGEAR WGR614v7 wireless router:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 26, 2009
My Toshiba M55-S3314 can detect wi-fi but cannot connect.
If your laptop has a software that manages your wireless connection, uninstall it. Then go to Control Panel > Network and Internet > Network and Sharing Center, then click on Manage Wireless Connections then remove all wireless networks that are saved there then restart your computer then try to connect again to the wireless network.
Hope that solves the problem. =)
Apr 11, 2011 | Toshiba Computers & Internet
I have a toshiba satellite a135 s2276. When I try to connect wirelessly to my new router or anywhere that offers the service, I get e.g. "THIS COMPUTER IS CONNECTED TO LINKSYS BUT DOES NOT HAVE ACCESS TO...
Hi there.
If the other laptop is connecting fine then the problem lies with your laptop, possible bad drivers.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
keep me informed please as a download of the drivers may be required.
Good luck
Jun 15, 2009 | Toshiba Satellite A135-S2276 Notebook
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop wireless connection
assuming you have set up the router to enable DHCP which automatically detects pc's and assigns an automatic ip address, and assuming you are using XP and not Vista, although the workthrough is similair; go to open internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked, then apply and exit IE
Next go to control panel>network connections, double click your wireless connection icon, select the TCP/IP line and click properties, then make sure obtain an ip address automatically is ticked, apply it ok, then open IE again and click the refresh button a few times.
Sep 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M105 - will not connect to the Internet...
the wireless card may need a new or updated driver to be compatable with the network
Jan 02, 2008 | Toshiba Satellite M105-S3004 Notebook
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
11,346 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
