Question about GE 106585 Upright Vacuum
Were can i buy a cone fllter - GE 106585 Upright Vacuum
  • GE Master
  • 18,424 Answers
You can get all spares for GE106585 from the link below.
http://www.appliancefactoryparts.com/vacuumcleaners/brands/ge/106585.html
Posted on Nov 09, 2012
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
The red light by the on and off switch turned on . what does that mean
usually it indicates a low suction issue. Wether the hose is clogged, or either one or all 4 filters need to be changed. Usually the cone and the circular filter above the plastic cone should be replaced.
Good luck,
Mark
Nov 07, 2010 | Filter Queen Majestic Canister Vacuum
Red light is on my filter queen
The red light on the filter Queen is on to tell you to empty the canister and change the filter. It is a heat sensor that makes it come on and if it is full it gets hot. Also when you take the motor piece off of the bucket under the nylon cone shaped guard that protects the motor there is a secondary filter in there that needs to be changed from time to time and they are supplied with the cones inside the package of rep[lacement cones there should be a spare or maybe two. It is a round thin filter about 3.5 inches across and it just fits in very easily and there is a plastic ring that holds it in place. So pop out the ring and remove the old one and then replace it with the new one put the ring in to hold it...it just snaps into place.replace the nylon guard and put in a new filter cone. Put the machine back together and away you go the light should turn off and you are good to go. Thanks for your time and please try to remember to click on the yes box if this was any help to you at all.
Oct 10, 2010 | Filter Queen Majestic Canister Vacuum
My filterqueen majestic is 10yrs old and just started to spark and smell of burning ive took it apart
If you have a burning smell from the motor, your motor is shot. You should be able to buy anew AMTEK Lamb motor for about $85-110 US. Request a double ball bearing motor as it will have a longer life span.
Also buy a fresh internal filter kit. There will be a small 5 .5 inch filter disc inside the cone protecting the motor in the event that the cone tears. Replace it .Also save and reinstall the small insulating disc that sits between the top of your motor and the screen at the top of the vac. This is to prevent electric shock. This disc is the size of a coin.
Post back if you need more help. Wiring is very easy. Do NOT twist your wires before installing into the connectors, twist the connectors, then tape to be certain they are on tight.
Nov 04, 2009 | Filter Queen Majestic Canister Vacuum
How do I take it apart to empty the cone?
the cone where the dirt goes in will twist off about 1/4 turn and then lift out the filter to empty
Oct 24, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
I was given a filter queen majestic limited edition but have no manual, can you help
This is a very straight forward good quality vac, with excellent filtration.
The cannister has two large clamps to release the motor from the dust chamber. Depending onb the age you may have an LED which comes on when it is time to empty the vac. The cleanest way to empty is to leave the paper cone over the dirt and carefully tip all into a garbage bag sitting on the floor.
You should replace the paper cone with a genuine fresh one each time you empty the container. In addition there is a paper disc inside the motor housing which you will access by removing the flat screw at the bottom of the plastic grille cone.
Sep 03, 2009 | Filter Queen Majestic Canister Vacuum
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Filter queen majestic
Has the cone filter been replaced?
Do you know how to check the grey filter which is inside the cover where the cone filter goes into/
Jun 09, 2008 | Filter Queen Majestic Canister Vacuum
GE 106585 Upright Vacuum Logo
21 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
