Question about Homelite Garden
What spark plug does a Homelite 2200 PSI pressure washer use?
I need a new sparkplug for a Homelite 2200 PSI pressure washer. The other one taken out to take to the store to find a replacement, and lost. So I can't take it to the store. Can someone give me some type of model number by any chance? Thanks a lot.
  • Ian C Nov 08, 2012
    p.s. it's a few years old and has the Honda engine in it.
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
Testimonial: "yes - your info was helpful Thanks Greg"
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
MOTORWIZJ
  • 1368 Answers
SOURCE: I have a husky 2200
20 thousands or about the width of two match book covers stacked.. there not that fussy, good to be close though
Posted on Jun 06, 2011
mc1bean
  • 3053 Answers
SOURCE: water leak where the gun
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Posted on Jun 08, 2011
How come my Homelite pressure washer will not turn over?
remove spark pluug and squirt some fuel into the hole . quickly put plug in and try to start. often this will help the motor get going and might not need anything else all season.
Aug 12, 2014 | Homelite Garden
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
No spark on Homelite 2500 PSI , 2.3 gpm power washer
Hi executive342
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Please take time to rate me
Bud
Oct 07, 2012 | Homelite Workforce 2500 PSI 23 GPM Axial...
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
I have a husky 2200 pressure washer. What do I set gap on spark plug. (Lost insturctions)
Jun 06, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
Does not start. what could be the problem?
Make sure the oil level is right. Check for spark by removing sparkplug and reattach the plug wire on it and ground the nut part of the sparkplug on metal on the engine. Whith the switch switch to on you should see a spark between the gap of the sparkplug when you pull the cord. If not get a new plug and make sure it is gapped to 30 thousands. If you are getting spark put the plug back in and tighten and reconnect the wire. Take the air cleaner off and put a spoon full of gasoline in the carburetor and pull the cord. If it fires for a second the carburetor has to be taken apart and cleaned.
Mar 12, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
What Spark Plug do I use for my Blue Max 2200 Power Washer.
Spark plugs: BPR6ES (NGK), W20EPR-U (DENSO). You cna cross ref any other equivalent with a spark plug cross ref book.
Thanks for choosing Fixya.
Kelly
Aug 12, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
engine:
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
102 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
