Question about U-Line Refrigerators
Uline wine fridge 2075-wcs not cold enough
The wine fridge is running and pumps cold air, but even at the highest setting it doesn't appear to be cold enough.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Posted on Nov 22, 2013
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
woodchuck789
  • 4066 Answers
SOURCE: freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Posted on Jul 01, 2009
  • 286 Answers
SOURCE: Describe your uline wine cooler Problem
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Posted on Jul 20, 2009
aasc
  • 1606 Answers
SOURCE: blowing cold air but not cold enough to keep frige cold
IF there is frost on the back wall inside the the freezer section about 12 inches from the bottom , you have a defrost problem . If there is no frost on the rear wall , then you probably have a bad overload/relay (part # 2188840 ) . This piece is the part which is plugged onto the compressor , with 2 or 3 wires going to it . Unplug it from the compressor and shake it . If it rattles , replace it .
Posted on Aug 02, 2009
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Uline wine refrigerator won't get cold
how old is it thay usely last a year or so set it tovery cold
May 25, 2012 | U-Line 15WC Wine Cooler
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Right side cannot get cold enough even at the highest settings
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 07, 2010 | Maytag MZD2766GES Side by Side...
Wine cooler (uline) not cooling, previously had thermostat replaced
Make sure that you have enough air flow around the unit and that the grill on the bottom is clean and free of dust/pet hair ect..also take into consideration of the location of the unit... make sure it is not next to a heated appliance like a dishwasher or range. and remember that it is not a frig it is a wine cooler so it will not get really cold.... if it has a glass front make sure it is not sitting in direct sunlight for extend periods of time as this will cause the unit to run excessively. I hope this helps.. I hate warm wine..
Nov 11, 2009 | Refrigerators
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Oct 06, 2009 | U-Line 75WC Wine Cooler
Freezer keeps frosting up and fridge doesn't get cold enough
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerators Logo
141 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
