Question about Tools & Hardware - Others
I have coleman evcon furnace natural gas it doesn't not light
SOURCE: evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Posted on Mar 06, 2009
  • 115 Answers
SOURCE: Evcon Coleman mobile home furnace needs repair
if you know what the flame sensor is try gently cleaning it with sandpaper they get gummed up sometimes and don't sense the piolet flame, if they don;t see a piolet it will not allow it to kick the gas on
Posted on Oct 10, 2009
  • 221 Answers
SOURCE: i have a coleman evcon furnace and it wont work it
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Posted on Dec 31, 2009
  • 221 Answers
SOURCE: COLEMAN EVCON FURNACE .. The draft fan keeps
Make sure the Thermostat fan switch is in the "auto" position.
  • 221 Answers
SOURCE: need schematics for coleman evcon presidential
The schematic is inside the panel where the wiring is.
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
My Coleman Evcon Magnum model DGAM056BDC comes on but goes right back off again. I had the house tented and the gas man thinks they could have pushed the cap on roof. What does the blinking red light...
it the house has been tented and now the furnace doesn't function correctly then you need a Heating and Air professional to check out your system
Oct 21, 2011 | Tools & Hardware - Others
My furnace is a Coleman Evcon DGAT090BDD and it won't turn on at all. The green light is solid green, I can't find the pilot light, and its freezing in here. Please help me!!
Your furnace has an electronic ignitor so there is no pilot to lite...... I would shut power off to the furnace and then restart it....this will reset the control board and take it out of lock out..... If the hot surface doesn't glow after you restart it then it is probable burned out and will have to be replaced.....It is inside the furnace right behind the Gas Valve. Will have two wires running to it from the control board....If you can't get it goingby shuting off the power and reseting it then you many want to call your Service Company to have them check it out.....
May 05, 2011 | Heating & Cooling
I have a coleman evcon furnace Model BGU075. sometimes the automatic ignitor comes on but the furnace won't light
Check your gas flow...clean the sensor...and be sure your gas switch is in the right pposition
Nov 20, 2010 | Coleman Heating & Cooling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
Tools & Hardware - Others Logo
81 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
