Question about Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888
3/8 air rachet will not stop spining - Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888
  • 27 Answers
The ratchet needs repair. I would check the throttle lever valve inside. Either the spring inside or the valve o-ring are worn out.
Posted on Feb 18, 2013
My candy 1862d will wash but wont spining.i tried once blowing air through d pressure switch to clear any blockage and it spinned but now its not spining even when i performed similar operation
sounds like a faulty pressure switch , or the small pipe connected to it is blocked, machine will not spin if is seances water in the machine. you hear a small click if you blow very gently into pressure switch and as you stop blowing and the air comes out you hear another click as the switch operates
SAFETY always make sure the machine is unplugged from the mains electrical supply before working on machine.
Nov 20, 2016 | Candy Washing Machines
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
It keeps spining will not stop
Air rachet? The valve probably got something in it and won't shut down the air flow. You will have to take the valve portion apart and clean it out. Look for any bad o-rings while you have it tore apart.
Feb 05, 2012 | Craftsman Professional 38 in Ratchet...
Craftsman 3/8 ratchet model 875-188020 no power
Check the O-rings in the rachet, itf they are leaking then the rachet will not work.
Jan 11, 2012 | Craftsman Air Tools & Compressors
I have a milwalkie 1/2 inch drive air rachet ...all of a sudden now it wont work when you hit the trigger air just comes out where the top of the rachet joins to the bottom half...is there a way to fix it?
it sounds like the viens in the air motor may be stuck. try pouring some "Air Tool Oil" or any thin oil will do, even veg oil. when pouring it in make sure to pull the trigger so that the oil goes into the ratchet. let it soak for a while and try it. I hope this works for you.
Apr 16, 2011 | Air Tools & Compressors
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
My dvd burner stops spining on dvd's but no cd's
Your dvd must be not supporting the burning process on dvd's and thus stops spinning or it may be in a error condition.
Aug 10, 2009 | Memorex (32023282) DVD±RW Dual Layer...
Studs on the waterpump are free spining...
those a pressed in the sheet metal cover.. you can try to put pressure on the water pump pry it away slightly and then use a air rachet if you have one available.. that should work for you ..
Feb 19, 2009 | 1985 Cadillac Fleetwood
Locked up agitator,
If your agitator is a 2 piece, it has a rachet action and turns free counter clockwise and locks to the bottom piece when turning counter clockwise.
The transmission disengages the agitator when it is in the spin mode. If you put the washer in the spin cycle the agitator should free up.
If the washer is spining ok and the agitator is not turning free you have a transmission problem.
Jan 27, 2009 | Admiral AW22 Top Load Washer
2000 323ci tractn ctrl lt comes on and stops power to rear wheels
THE LIGHTS COMES ON WHEN ONE OR TWO WHEELS STARTS SPINING (WHEN TERES NO TRACTION) ITS STOPS THE CAR FROM SPINING SO ITSTOPS POWER GOING TO THAT WHEEL.
MAKE SURE YOR TYRES ARE INFLATED RIGHT OR YOUR TYRES ARE WEARING OUT
Nov 14, 2008 | 1999 BMW 323 Series
Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888 Logo
432 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
