How do i clean lint from thor softline washer dryer combo?
I have read that when it takes a long time to dry, the problem is often caused by lint buildup. how do i clean lint buildup? where would the filter be? other parts i'd need to check?
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
  • 1294 Answers
SOURCE: LG WM-3677HW dryer cycle does not dry and lasts for 3 minutes
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl ...........if helped.
Posted on Jan 03, 2008
SOURCE: Supra SW5L30D parts
You can get parts for the Supra SW5L30D from EdgeStar (can't figure out if EdgeStar bought Supra, or if Supra just changed their name or what). 866-319-5473. I've been able to get the parts I've needed, though they're not the most efficient operation. One time I had to wait for someone to get back from vacation before the part could ship...
Posted on Jul 13, 2008
  • 168 Answers
SOURCE: Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Posted on Nov 02, 2008
SOURCE: Supra Wash/dryer combo Model SW5l30D
check the heating element for power.
Posted on May 03, 2009
Hirundo washer/dryer fills with water during the dry cycle so clothes come out hot and soaked what could be the cause?
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
Why Would Find Water in My Dryer eHow
Jun 09, 2014 | Equator EZ 3612 CEE Front Load...
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Dryer model # lte5243dq3 take to long to dry clothes
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Apr 17, 2011 | Whirlpool LTE5243D Top Load Stacked...
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
Clothes take at least 2 hours to dry. cleaned out vent and all lint in lint trap and squirrel cage motor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 24, 2010 | Maytag Dryers
Dryer not heating like it was before. It does not dry in one cycle. It takes 2 60 minute cycles to dry clothes.
If your
Dryer Maintenance
heatman101
Aug 19, 2010 | Kenmore 98702 Stacked Washer/Dryer
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
