Question about Fellowes Powershred 480 Shredder
Fellowes powershred 480 repair manual - Fellowes Powershred 480 Shredder
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
Posted on Feb 22, 2008
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
FixinFax
  • 3085 Answers
SOURCE: Looking for a manual on a Fellowes 220 Powershred
There are no spare manuals or parts,
Blow canned air down into the feed slot, then lube with Marvel Oil generously..
Posted on Oct 23, 2009
SOURCE: Where to oil a Fellowes Powershred 320 CC paper
I continued to search via Google until I found the manual for this shredder, which I then printed out and read how to lubricate the shredder.
Posted on Jan 26, 2010
  • 215 Answers
SOURCE: Having a problem with Fellowes powershred 480 cc.
you have 2 sensors in the throat of shredder. one on front side and one on rear side of throat. take a q-tip with alcohol and clean them as good as you can. if that doesn't do it, its a possibility you have a bad on/off switch or worse, a board problem.
hth,
razors
Posted on Feb 01, 2010
HOW DO I MAKE A FELLOWES C-480C SHREDDER PUMP OIL
Hi Wendy, push and hold down the "bulldog" button and then hold down the "forward" button. You should hear the pump pumping oil. May take15 seconds before you hear a hum. If you do not hear anything, the pump may have to be replaced. Clogged oil nozzles or tubes could also cause a problem. This is a common problem and Fellowes re-engineered several components to fix this problem. You can google Fellowes to get a phone # to find an authorized service center. good luck.
Nov 20, 2014 | Fellowes Powershred 480 Shredder
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
How do I clean the sensors
Before you do anything with this machine unplug the power lead. Switching off is not enough.
Everything you can do is in the manual:
link to Manual Fellows 480
Nov 13, 2013 | Fellowes Powershred 480 Shredder
Powershred 480 When activated the motor will not run but if turned it will run in the direction turned. the motor is new.
see if a condenser or capacitor is used to assist the starting of the motor and if so change it
Dec 19, 2012 | Fellowes Powershred 480 Shredder
Do you know anyone who fixes Fellowes Powershred 480 machines in Camp Hill, PA area?
Ribbons Express 499 Running Pump Rd.
Lancaster PA 17603
Ph:800-533-9949 They are the closest
Mar 30, 2011 | Fellowes Office Equipment & Supplies
Having a problem with Fellowes powershred 480 cc. Rollers do not move forward, only in reverse. Any ideas?
hth,
razors
Jan 21, 2010 | Fellowes Powershred 420CC Confetti-Cut...
Regarding powershred 480
I have a similar problem with the bin full light and understand I have to clean the sensors. The sensor you could be having trouble with is probably up in the feed slot area. Have a look at it with a flashlight and see if there is paper dust covering the sensor. I clean mine with a toothpick.
I haven't had much luck in finding an official description of where the sensors lurk, just trial and error.
Hope this amateur suggestion helps.
Jul 29, 2008 | Fellowes Powershred 480 Shredder
Main board
There is a possibility that Fellowes customer service will be able to obtain this info. 1-800-945-4545
Jan 25, 2007 | Fellowes Powershred 480 Shredder
Fellowes Powershred 480 Shredder Logo
103 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
