Question about FocalPrice HAME A11W 3G 7.2M Integrated Wireless Router White
My problem is where the imei number in hame a11w
I need to make the conection with the data plan with the telephon company they need the imei number for e make the conection
Problems with gmail on my alcatel onetouch pop
Whoa! You've got a lot of apples and oranges mixed in here. It sounds like you are talking about your cellphone?. So do you already have internet access on that unit? You didn't say. If you don't, then you need to get a data plan from your carrier if the phone will do data. All smartphones will.
If you have a computer, then depending on exactly where you live you can get high speed cable internet, DSL from the phone company, or wireless from AT&T, Sprint, and most cell carriers.
Once you are on-line, just open your browser, go to Gmail.com and sign in. There are no phone numbers involved...that's a holdover from the dial-up days. This also applies to tablets that can accept a data plan. Most of them come with a gmail app that will take you right there if your phone/tablet has a data plan.
You can't use your cellphone to 'dial-up' an internet connection like we used to do with modems. That's not how these devices work. Dial-up still exists and for some that's the only option, but for that you need a regular computer with a modem. Plus it's slow as molasses.
Jun 15, 2014 | Computers & Internet
Unlock hame compatible with celcom 3g
1. Go at A11W UI by set in the URL of your browser the address 192.168.169.1 2. Go at the Login > Admin > Settings 3. At the end of page press the Export Button. Now, a file with name RT2880_Settings.dat will be saved in you hard disk. 4. Open the .dat file with notepad program. 5. Search for lines "CountryRegion" and below "CountryRegionBand". After symbol "=" delete the value (ATTENTION, lines to be remaining one below the other). Save file and close. 6. Repeat steps 1 & 2 above 7. Below button Export select button Select File. Press and select the .dat file tha you save before. 8. Press Button import. The .dat file will be load your new settings and A11W will restart. 9. You can use after any supported SIM card around world. Good lack!
Feb 05, 2013 | FocalPrice HAME A11W 3G 7.2M Integrated...
How do i get my imei number?I KNOW LONGER HAVE VERIZON PHONE SERVICE (DATA PLAN SERVICE)
Your IMEI number should be located in the battery compartment. You may have to remove the battery to find the number.
Aug 03, 2011 | RIM Blackberry Curve 3G 9330 9300 8520...
Sir i lost my mobile which a nokia 1600 series and with mobile number of reliance GSM 8099120787 how i can get my IMEI number so that i can block my mobile phone.............
If you still have the box it came in, it would be listed on the side. You can also contact your provider and see if they keep that on record. You can also report it to them as being lost, however that doesn't prevent someone else from using it. Other than that, there maybe no way of getting it.
Mar 01, 2011 | Nokia 1600 Cellular Phone
Whats the nokia c3 code
You can obtain a Nokia C3 unlock code by calling your wireless telephone company, who will ask you to provide your IMEI number - which is unique to each Nokia C3 device.
To obtain the IMEI number for your Nokia C3, type *#06# and hit enter or send. The carrier will use this IMEI number to calculate your unique unlock code.
Feb 19, 2011 | Nokia C3 Cell Phone
On the m9516 what is the fax switch on and off used for?
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
Note:
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Jan 30, 2009 | NorStar Meridian M9516 Phone w/ Digital...
FocalPrice HAME A11W 3G 7.2M Integrated Wireless Router White Logo
67 people viewed this question
Top FocalPrice Computers & Internet Experts
Stu Ungar
linda
linda
Level 1 Expert
sarathink
sarathink
Are you a FocalPrice Computer and Internet Expert? Answer questions, earn points and help others
