Question about Nokia E71x Cell Phone
Normally, you can't charge a Nokia E71x via usb because it isn't wired that way. You normally have to use the 2mm power plug with the supplied DC power adapter. I'm wondering if you could run wires from the micro usb data port on the side of the phone to the charge port on the bottom in order to charge via usb.
  • Nokia Master
  • 32,281 Answers
The best way is to get a power adapter. try Google the Internet for a charger for the Nokia e71x.
Posted on Nov 09, 2012
5 Suggested Answers
dr reed
  • 379 Answers
SOURCE: need an unlock code for any service for a nokia e71x
Hope I helped Dr Reed
Posted on Apr 05, 2010
dr reed
  • 379 Answers
SOURCE: Unlock Code for Nokia e71x
I hope this helped Dr Reed
karankr
  • 274 Answers
SOURCE: My Nokia E71x started to lock up and wont turn on now.
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Posted on Jun 18, 2010
jocoolguy
  • 1912 Answers
SOURCE: nokia e71x pin code blocked , enter puk code
Service Provider will give the PUK Code....You can call them..
Posted on Oct 20, 2010
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Jun 12, 2013 | Dell Android 2.3 Touchscreen 7" Internet...
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
One lg vu 920 turns off after 5 seconds and the second wont recieve service
  • Keyboard issues (no predictive text):
    • This isn't a "fix" per se, but it seems the best route is to use an alternative keyboard. Swype is pre-installed on the phone, so you can switch to that without installing anything new. Alternatively, you can try other players such as SwiftKey, A.I.type, and TouchPal. Otherwise, LG is aware of the issue and working on a fix.
  • Phone won't charge
    • The potential fix is to enable USB Debugging. To do so, head to Settings -> Applications -> Development -> make sure USB Debugging is checked.
    • Alternatively, if it won't charge normally (while powered on), it should charge while powered off. Your best bet is probably to power it off and let it charge while you sleep.
    • For some people, it seems that the phone actually is charging, it just doesn't show it.
  • Can't use USB storage
Unfortunately, there are no perfect fixes for any of the issues listed above. Other users are reporting a smattering of smaller (and substantially less frequent) issues, but hopefully the above can help some people with the most significant issues.
Mar 02, 2012 | LG Cell Phones
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see http://www.samsung.com/ph/consumer/monitor-peripherals-printer/optical-disc-drive/dvd-rw-drive/SE-S084C/RSPN/index.idx?pagetype=prd_detail
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
When I attempt to charge my moto q via an power outlet or car charger the charge powers the phone but not the battery. when I attempt to charge it by computer it there is normally a 30% chance it will...
I have the same problem with my iPhone. The only real way and best way to get a charge on a phone is through a wall charger. Car chargers and computer/usb to charge doesn't actually do anything but "top off" the battery. They don't produce enough power to give the batter a strong charge like the wall can.
That's my best advice. Charge from the wall when at home. Use the car to top off when your on the go.
Oct 20, 2011 | Motorola Mobility Moto Q
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Nokia E71x Cell Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
