Question about Black & Decker Travel Pro X30 Iron
I love the Black and Decker Travel Prox30 Iron... love!!!! I want another one just like it... where can I dfind one?
  • 1,564 Answers
Apparently the Pro X30 isn't made anymore. They have one called the pro x 50 now.
http://www.amazon.com/Black-Decker-X50-Travel-White/dp/B000M4EY06
Posted on Nov 13, 2012
SOURCE: Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
Posted on Jun 16, 2007
  • 4 Answers
SOURCE: Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Posted on Feb 18, 2008
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
SOURCE: iron saying "error"
my **** is to big for my girls friends ***** how do i get it in?
Posted on Sep 19, 2009
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
Aug 19, 2009 | Black & Decker D2030 Iron
Where can I obtain a users manual for the Black & Decker AS675 iron?
Please visit www.useandcaremanuals.com or call Black & Decker customer service at 800-231-9786 for the manual you need,
Please post a comment if you need additional assistance.
Jul 12, 2009 | Black & Decker AS675 Iron
I have an older Black and Decker Prestige x850 iron, had for about 4 years, it is not cordless. It just stopped working during my ironing the other morning. Love this iron, tried to plug in again, no luck,...
Might be really tough getting it repaired somewhere.. I cant think of anyplace that would make these types of repairs.
Might be better off finding one on ebay - if they are not on the shelvs any more..
Jul 09, 2009 | Irons
Describe your Black & Decker
Please call Black & Decker customer service at 800-231-9786 so that we may determine your warranty status. Mon - Fri. 8:30 to 6:00 EST.
Jul 07, 2009 | Black & Decker AS150 Iron
Black & Decker AS150 iron
Bought a new iron and it is not a Black &Decker.
Jul 15, 2008 | Black & Decker AS150 Iron
Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 11, 2008 | Black & Decker D2020 Iron
Melted material on face of iron
Yes- I had the same problem and could not clean it off. It was a plastic sticker that melted on the iron plate- placed there by the manufacturer. I called Customer Service at Black and Decker, and after all their solutions failed- they sent me a new iron. But this one leaks water terribly to the point where the clothes are soaked after only 1 or 2 articles are ironed! I am beginning to lose faith in Black and Decker products.
Dec 24, 2007 | Black & Decker D2030 Iron
Black & Decker Travel Pro X30 Iron Logo
110 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
