Question about Samsung RS2630WW Side by Side Refrigerator
Noise on the ice maker
I have one year old Samsung refrigerator and they make a lot of sound sometimes. When I open the door the sound is gone when the door close it makes sound. I called a few appaliance repair store they don't do those brands. What can I do?
  • Todd Born
    Todd Born May 11, 2010
    where is the noise coming from approximately and do you hear it all the time.
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Posted on Feb 02, 2009
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
My Samsung RF265ABWP French door refrigerator has suddenly stopped making ice. I hear the old familiar noise it used to make just before I heard the ice drop in the bucket, only no ice drops. It sounds...
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Nov 12, 2017 | Samsung RF265AA Bottom Freezer French Door...
My Whirlpool bottom-freezer, french-door refrigerator is 3 years old. All the lights work fine, as does the ice-maker, and the main compartment cools as it should. The problem is: the compressor motor...
Newer model refrigerators run a lot more than older ones but you could have leaks around gaskets, check freezer compartment and see if there ice buildup around door if so let this defrost by turning off if possible. The defrost circuit should take care of this but sometimes in very humid weather it does not.
Aug 02, 2017 | Whirlpool GI5FSAXV Bottom Freezer French...
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Sep 03, 2010 | Samsung Refrigerators
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
191 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
