Remove power from the range and go to the back of
the control and disconnect the P3 plug. Measure
the resistance between pins 3 and 4. If the meter
reads infinity check the oven door switch and the
wiring to the door switch. If the meter reads zero go
to step 2.
2. Measure the resistance between pins 1 and 3 of
plug P3. If the meter reads infinity switch A of the
lock motor assembly or the wiring to switch A is
defective. If the meter reads zero go to step 3.
3. Measure the resistance between pin 5 in plug P4
and terminal N. If the meter reads zero or infinity
the lock motor or the wiring to the lock motor is
defective. If the meter reads 2350 Ohms replace
the electronic oven control.
Thanks for choosing FixYa,
Kelly
Found it on the very top of the configuration page under system reference. Its called pages printed and its the 2nd item down on the left hand side of the page
