Question about Honda Garden
How to check fuel pump for honda gc160 - Honda Garden
2 Suggested Answers
SOURCE: honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
Posted on May 07, 2009
I have gas in my oil on my honda 5.0 gc160
Check the engine compression with a compression tester. Most likely you have a blown head gasket.
Sep 19, 2014 | replacehondaengines.com Honda 5.0 Hp...
I have a honda GC160 prssure washer. I tfires up good, but when you squeze the trigger no waters comes out of the gun?
Hiand welcome to FixYa, I am Kelly.
GC160 is the engine number.... It does not tell me that pressure pump is on the unit.
There should be a large knob on the side of the pump head. That is the bypass / unloader valve. Removed that and clean the pump housing where the flat plunger mates to the bousing. Then disassemble the unloader vavle. Remove the lower part of it from the knob and clean off the corrosion and dirt from the plunger and spring. Clean everything brass.... Reassemble using what you could consider abnormal amounts of WHITE GREASE. Place a GOB of white grease into the pump housing be re-installing the unloader / bypass valve. Just remember when you hook up water for a funtional test, that your going to spray some off that extra white grease through the pump and wand nozzle.
This should get you going again. If not I need a model number for either the pump body or the whole pressure washer vs the Honda engine number of GC160.
Thanks for choosing FixYa,
Kelly
Aug 01, 2011 | Garden
My gc160 pressure washer will start with a 'gunk' spray but dies right away.
it is not getting fuel.check if carb is getting fuel from tank, by removing hose at carb. make sure airfilter is clean ascarb cannot vacuuum in fuel if its dirty, try staritng without filter on.if all that is good, you will need to remove bowl from carb, may be dirty
Aug 09, 2009 | Honda 8 HP Engine
The tubing from the gasoline is not connected
Devilbliss / Excell pressure washers in this model number range use a Honda GC160 engine. Information on this engine can be found here:
http://www.excellpressurewasher.com/documents/pdf/gc160.pdf
This web site also has information about the pump and related parts just look for your model number. I find that pressure washer manuals have very little information about the engine. Small engine / mower repair shops in your area will be happy to give you free information about the where the fuel line attaches. Your engine has a black plastic fuel pump with hoses going to tank and carb. This fuel pump is powered by engine crank/vacuum purssure so there is a third hose from the fuel pump connected to the engine block. Good luck on your repair and email if you have a question or if you have a different engine than mentioned above.
May 09, 2009 | Garden
Honda 5hp engine wont run
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
658 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
