Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
The third prong on the cord broke off ,,, can I still use
I was using my rule 1800 ... now it won't turn on. I was running it with the "third" prong broken off ,,, i guess it is the ground ,,, does that matter?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Yes it matters. You can buy a 20 amp 3 prong from Lowes and re wire.
Posted on Dec 01, 2012
2 Suggested Answers
SOURCE: broken garden hose adaptor
We have the same pump and problems. I have attempted a few fixes with PVC sealant and hose clamps to the current adaptor, however the adapter is still continuing to crack. The adapter is removable- carefully so as to not damage the small eyelet it attaches to, (or in our case, it came off on it's own) and can be replaced by any adapter that fits- they can be found all over at lowes or home depot. I am personally going to try using a broken hose and clamping it directly to the eyelet. This is not a good reason to buy a new pump- they fix too easy!
Posted on May 07, 2009
Panasonic sb wa920!! my receiver broke and im wondering how to use the the speakers without the receiver?
How bypass to get sound through the sub I don't have that cord to sa - Ht 920
Apr 23, 2014 | Computers & Internet
Will amp still work after third prong is broke
If the third prong is the round one, then that is the ground to your amp. It will still work, however, the amplifier will not be properly grounded. So in a pinch you can use it, but you need to get the cable replaced. The ground wire is there for your safety, in case you plug your amp into a mis-wired outlet or if you are plugging in another instrument like a keyboard, mixer etc. that may be mis-wired. This could lead to a bad shock or worse. You have been warned.
Apr 22, 2014 | Roland KC550 Amp Keyboard
Goodman furnace won't run on generator
I work on Goodmans and I vaguely remember something like this.Be sure the neutral (white wire) and the green ground are the same potential. They both tie into the ground bus at the generator.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 04, 2018 | Heating & Cooling
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
I'm concerned about having the proper extension cord. Just bought 15' light duty outdoor cord with 2 prong plug-SJOW/ 13 amps/ 25 volts/ 1625 watts. Is this sufficient for the # 20070910...
There should be a plate on the smoker that tells you how many amps/volts/watts it uses. If the values are lower than your extension cord I would try it, however make sure you feel the cord after the unit has been on for a bit, if it feels warm or hot to the touch, I would discontinue use of the extension cord.
If you are in need of a user manual you can find a downloadable (.pdf) version here.
http://www.masterbuilt.com/support.html
Aug 06, 2011 | Masterbuilt 20070106 Electric Smoker
What kind of extension cord to use?
You should use a cord with the ground wire in it. If you're running a heater and the wire is getting hot, it's not whether it should be an indoor or outdoor cord it's the wire size that's the problem.
If you wire is getting hot you need a larger wire size.
Depending on the amps of the heater rule of thumb
15 amps a minimum of 14 gauge with ground
20 amps a minimum of 12 gauge with ground
30 amps a minmum of 10 gauge with ground
If you are using a cord over 15 to 20 feet then you may want to go to a larger wire size.
You will know if the wire size is correct if you let the heater run for a while 20 to 30 minutes and then feel the wire it should just barely feel warm it shouldn't get real warm or hot.
Dec 28, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
106 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
