Question about Garden
Drive chain pops off large gear
I have replaced the chain and large gear but the drive chain still pops off the large drive gear.
  • 32 Answers
SOURCE: I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Posted on Aug 31, 2009
  • 3197 Answers
SOURCE: Chain drive gear broke on my mod.1265LM.
The drive gear part number is 41A2817 and the price for the kit is around $25.00. It comes with instructions.
Posted on Dec 21, 2009
  • 332 Answers
SOURCE: Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Posted on Apr 01, 2010
puertobori
  • 7733 Answers
SOURCE: I have a 107624-02 saw. Motor of saw runs but
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams
also look at ToolPartsDirect.com - Your Tool Repair Supply Store.
Posted on Jan 18, 2011
  • 661 Answers
SOURCE: My motorcycle drive chain jumps specially in 5th and 4th gears , but no jump in 1st and 2nd gears. Motorcycle produces loud clunking/knocking/grinding noise when at hill. No clutch slippage, Whole
its not the clutch or chain its the gearbox by the sounds of it I would say the drive dogs on the gears in the box are worn away especially if it only does it in certain gears,what bike are we talking about here /???????????
Posted on Feb 20, 2015
My motorcycle drive chain jumps specially in 5th and 4th gears , but no jump in 1st and 2nd gears. Motorcycle produces loud clunking/knocking/grinding noise when at hill. No clutch slippage, Whole...
Feb 20, 2015 | 2011 Bajaj Pulsar 150
My 1987 GMC s15 automatic 4x4 pickup keeps popping out of normal gear. The only gear it stays in is 4 low. Where do I start?
I'm assuming you're talking about the transfer case popping out of 2 high or even 4 high. It could be that the transfer case needs a chain or gears replaced and is slipping on the cogs/gears. In 4 low it takes less pressure/strain to move the vehicle so it doesn't slip. I would put the trans. AND transfer case in neutral, with the FRONT wheels blocked, and NOT running, jack at least one rear wheel off of the ground, and try turning the rear drive shaft back and forth to feel the free play (free play in the transfer case, not the rear end). Excessive free play should tell you that the drive chain/gears are very warn and could be slipping. That would be a start.
Jun 08, 2014 | Cars & Trucks
Yard king snowblower, drive chain keeps coming off gear
one of 2 things.if your spockets are worn the travel distance has shortened and where the master link connects replace the link that connects it with a half link.also is there chain tighteners on it?if so and they are on both sides of a spocket or just 1?if there are 2 they must be tightened together in unison and not 1 side or the other as that will throw the correct alignment on the chain and it will jump the spocket.also check the spocket alignment to make sure that is correct.
Jan 28, 2013 | Garden
I have a Husqvara 550 chainsaw. After chain popped and I put it back on, the chain won't move. It's on the gear and everything. Is there a brake or something preventing the chain from mov
There will be a chain brake, grab the brake handle and pull it firmly back to the top handle, this should didd engage the brake, if the chain has de railed the drive lonks will have burs on them which will make it tight in the bar, you need to file all these burs off.
May 05, 2012 | Husqvarna Garden
Replacing chain gear drive 028
It just pops off, keep tugging. Same for an 038
Nov 13, 2011 | Stihl Garden
When i put in 4 wheel drive i got a clicking popping sound and when in 2 wheel drive it sounds like a rattling sound that gets louder the faster you go
Sounds like gear and chain need to be replaced in transfer case.
The popping and or clicking is the chain trying to climb up over the teeth on the gear in transfer case.
May 19, 2011 | Jeep Grand Cherokee Cars & Trucks
Have Ryobi 40cc 18", have
Release the chain brake and remove the bar and chain. Clean the side of the engine where the bar fits to, then start the engine and see if oil oozes out of the side port on the engine. If it does, then clean the small oil passages in the drive end of the bar that run out from the large holes to the chain groove on each edge. If the oil does not ooze out of the port, then the oil pump, oil line, or oil filter in the tank may need service. Many oil pumps utilize a plastic gear that takes drive from the crankshaft behind the clutch and are prone to stripping the teeth of the gear. Hope some of this helps!
Dec 15, 2010 | Ryobi Garden
It goes into gear but it wont go no were when i put into gear it made this loud pop
you have lost all the drive to the rear wheel check the drive belt if it has one or chaine if there ok look at the drive sprokets if there ok pop off the cluch cover and have a look in there you may have striped the woodruff key in the crank shaft or gear box drive shaft
Nov 15, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
1996 chev 1500 pick up chain slips in transfer case under load?
Yes you can just replace the chain, I would not recommend it. Even if it is not obvious, the gears are also worn and have undergone all the stresses that stretched the chain, they may be ready to go soon, why take the chance, the engine has to be torn down to the same point to replace the chain as to replace the gears. I would replace all with a timing gear/chain set and install all new gaskets as it went back together. A timing gear failure could cost you a couple valves and/or pistons when it fails (piston on its way up with a valve stopped at full open when the gear broke).
Please take the time to rate this solution
Jan 29, 2009 | 1996 Chevrolet Tahoe
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
