Question about Maytag Atlantis MDE8400AY Electric Portable Dryer
Only the extended tumbler option works.
I have similar Maytag dryer model MDE8400AZW.  On any of the dryer settings, the dryer does not work (I will pull the handle and hold, the "damp" indicator light turns on without starting the dryer). I know it's not the motor because when I turn on the switch for extended tumble and turn my knob to extended tumble, pull the handle, the dryer will begin rotating as if nothing is wrong. I know it's not the door problem, because when I use my finger to press the door close "button" the interior light turns off and the extended tumble still works even though none of the other settings work. One strange problem I had was the turn switch.  Periodically, I would turn the setting to any random setting, try to turn on.  Repeating this at times would start dryer.  At first, I would only had to do this one or twice before working.  Later, I had to do this more and more.  Now it's not responding at all. I don't think it's the fuse because when I tried pulling the plug on the fuse, the extended tumbler doesn't work either. My first instinct was to replace the knob (I have not done so yet), but why is the extended tumbler working (every time) and nothing else? My guesses are 1. Knob is problem after all,  2. something is preventing any cycle that requires heat (maybe a thermomitor problem) One last thing, I've taken out the thermomitor (originally thinking it was the fuse).  When I shake it gently, I hear rattling metal pieces.  I'm not sure if this is normal or if it's broken.  I believe it's the maytag part 33002742.
SOURCE: Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Posted on Jan 23, 2007
kachbibi1
  • 979 Answers
SOURCE: maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Posted on Jan 21, 2009
SOURCE: Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Posted on Sep 13, 2009
Testimonial: "Thanks for the quick feedback! I will look for a replacement timer"
  • 56 Answers
SOURCE: Maytag PYE2300YW will not turn
maytag performa's have a thermal fuse located by the heater element located under the top back left corner
Also check for correct voltage to dryer
Posted on Nov 04, 2009
Daniel S
  • 4323 Answers
SOURCE: Maytag dryer won't start, light
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 04, 2011
Putting tumbler belt on dryer
Go to www.repairclinic.com and enter the model number of your Maytag dryer. You will be presented with a list of common repair parts and may be able to view a general video showing how to disassemble a typical Maytag dryer and make repairs.
May 22, 2016 | Maytag Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
Dryer makes wobbling noises when starting
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag MED5707TQ Electric Dryer
Maytag neptune dryer has three tumbler arms and one is loose. I can see set screws but do not know how to get to them.
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below (Should be similar to yours) to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Dryers
Maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
Dec 08, 2008 | Dryers
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE8400AY Electric Portable Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
