Question about Laney A1 65-Watt Acoustic Amplifier with Digital Multi Effects, Black
LA20C Laney ACoustic amp has stopped working, lights up for power on but no switches work any solution?
2 Suggested Answers
  • 5603 Answers
SOURCE: just bought laney rb9 bass
Best to leave the limiter on unless you want to blow the amp and require repairs. Limiters protect the amp and also sometimes the speakers. The limiters reduce the gain when the amp reaches the maximum swing. If the gain were not reduced the amp would "flattop" which results in the circuitry saturating and massive distortion and if this condition is sustained, components can overheat or short out requiring repair. The LED MAY be just an indicator of clipping rather than an indicator of on/off. I downloaded the manual and what I have just said is CORRECT. The LED is a clipping indicator.
There is a caution regarding this amp and the sequence to turn power on. This amp does NOT have good speaker protection and you have to have the gain control down when turning on. The limiter, if you leave it on, might help protect your speakers when powering on. Most good power amps have circuitry to disconnect the speakers while amplifier is powering up and becoming stable, this one does not, so heed the warning and for certain leave the limiter ON... It just might save the amp and your speakers.
Posted on Mar 02, 2011
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Hiss on laney A1
What is the impedance on the devices? It sounds to me like the amp and the pickups are not rated for each other.
Dec 16, 2013 | Laney A1 65-Watt Acoustic Amplifier with...
Unresponsive Acoustic channel 2 Marshall as100d ....
I have same problem. i have this map. please help me to find the problem. if you can point the area in this map that problem is from that.
Mar 04, 2013 | Marshall Amplification Marshall AS100D 2x8...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
Just bought laney rb9 bass amp, the limiter defeater LED doesnt light up when switch is in or out. how do i know if this is working or not?
Mar 02, 2011 | Laney RB9 300 Watt Bass Head
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
Laney GH50L guitar amp head and cab. The bypass switch works fine but suddenly the insert/side chain positions for the FX loop has stopped working resulting in the volume dropping so low and sounding so...
The symptoms are common to a capacitively coupled signal which is often a bad switch on an insert jack that is bent so as to not contact the signal to pass it to the power amp.
The jacks on MANY of these amps are plain JUNK. If a cable is yanked a bit it can bend the spring contact. When the conttact is very close, but not touching, the capacitance will pass the high frequencies but not the low and ALL frequencies will be very attenuated.
Oct 08, 2009 | Music
My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Mar 25, 2009 | Music
Low volume on acoustic and jazz amp type
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Apr 01, 2017 | Fender Fm25dsp 1x10' Guitar Combo...
Laney A1 65-Watt Acoustic Amplifier with Digital Multi Effects, Black Logo
49 people viewed this question
Top Laney Music Experts
rhodesworks
Steve F
Are you a Laney Music Expert? Answer questions, earn points and help others
