Question about Acer Aspire 5315 Notebook
My aspire 5315 is stuck on resuming windows... it won't finish loading to turn the computer on, any suggestions?
  • Acer Master
  • 7,627 Answers
Try re-booting, if that fails pull the plug from AC , remove battery, hold down on/off button for 10 seconds, plug into AC boot normally.
Posted on Nov 09, 2012
SOURCE: Windows vista on Accer aspire 5315 reboots over and over
i have probleme ;i look for driver webcam for acer aspire 5315
Posted on May 28, 2008
TORC
  • 53 Answers
SOURCE: My computer will not boot
Boot up and tap f8.
Start In safe mode.
Log out, switch to admin account.
Go to start menu and run.
msconfig.
Turn off all start up items and services.
Reboot.
GL
Posted on Mar 30, 2009
  • 311 Answers
SOURCE: missing PCI driver for Acer aspire 5315, running
you can check CD that come with teh motherboard and try to install it from there
Posted on Dec 29, 2009
  • 256 Answers
SOURCE: Acer Aspire 5315 Vista Windows boot problem
have you checked if your pc is compatible with win7? use this to check it: http://www.microsoft.com/windows/compatibility/en-us/default.aspx
and if it is, try to do a clean install. boot from the cd. insert the disc. restart pc, as soon as it has power, press F12 several times and highlight cd/dvd drive or ODD using your arrow keys then press enter. it will load the cd from there. And that should work fine.
Posted on Apr 03, 2010
sayedmohu
  • 645 Answers
SOURCE: Hello.My ACER Aspire One netbook
I would suggest u to do a power drain before contacting a tech.
For that remove the battery and unplug the charger.
Hold down the power button for 20sec.
Put the battery back in and power on the computer.
Posted on May 23, 2011
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
Aspire 5315 won't start up
When power on your notebook..........reinstalling operating system
Sep 26, 2011 | Acer Aspire 5315 Notebook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
How can i install my recovery cd on my acer 5315-2492.
The recovery disk consist of 2 DVD, the first is the System Disk (this is first disk to insert), once finished loading, it will ask to insert the second CD (Application and Drivers disk), if in case both are not working, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also place order for a set of Recovery disk by calling Acer Technical support at 1 800 816 2237
Thanks and regards,
Jitha
Dec 17, 2010 | Acer Aspire 5315 Notebook
I have an acer aspire 5315 and the screen goes black I have tried to go into set up and I have taken out bateries etc but it's still not working . Any help is greatly appreciated thanks
Hello mariawint589,
The following instructions are from the Acer Aspire 5315 user's guide (page 35):
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on, three hings might be the cause:
*The brightness level might be too low. Press <Fn>+<right-arrow key> (Increase) to adjust the brightness level.
*The display device might be set to an external monitor. Press the display toggle hotkey <Fn>+<F5> to toggle the display back to the computer
*If the sleep indicator is lit, the computer is in sleep mode. Press and release the power button to resume.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Nov 12, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Jun 07, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
