Question about Electrical Supplies
Garbage disposal jammed - Electrical Supplies
  • 5,245 Answers
Posted on Nov 09, 2012
  • 2976 Answers
SOURCE: Garbage Disposable won't work.
If the cutter plate will turn freely, look for a reset botton. Some units have them and depending on how it was installed, it will be around the back. It should be a push button, about 3/8" diameter. It takes a good hard push to reset it.
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
  • 308 Answers
SOURCE: Badger 1 1/3 HP Garbage disposal is stuck. I have
Can you turn the motor by hand? (with the wrench in the bottom of the disposal) If not then you either still have a restriction/jam or the motor is seized. If you can spin the motor somewhat freely with the wrench then you most likely have a bad motor and will have to replace it. Hope this helps
Posted on Oct 02, 2009
  • 151 Answers
SOURCE: my garbage disposal woll not drain
shut off the power supply to start, open the cabnit and look under the unit there should be a resess in the center where you can fit an allen wrench into and turn to check for debris in the unit. Work it back and forth to loosen any possible abstruction. Turn the power back on and try the switch if this doesnt work you need to remove the trap from the drain underneath the sink. Its a U shape piece of pipe that catches debris in it and prevents sewer gas from entering the home.
Posted on Dec 24, 2009
Kemore garbage disposal 6010 repair jammed
Use broomstick to un-jam the disposal cutter disc
Or use allan wrench on bottom of disposal
Following link has illustrations and tips for repairing disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 20, 2014 | Garbage Disposals
Garbage disposal is jammed kitchen aide kwd-200a
Use broomstick:
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Sep 07, 2012 | KitchenAid Batch Feed Garbage Disposal...
The garbage disposal hums but won't work. What could it be?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sounds like its jammed . used tool to free blades. it fools loose,but still wont spin
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Jan 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal won't turn on. Appears to be clogged
heatman101
a
Sep 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Pro 17 Inksink cover control erator garbage disposal that is not working. Will a Inksinkerator cover control evolution fit good in the same place?
Hi, Yes, that will work...
Sep 19, 2010 | Now Evolution In-Sink-Erator COVER CONTROL...
Loud humming sounds.I do not think anything is jammed. Cannot reset!
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
88 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
