Question about Singer 2662
I have a Singer 2662 sewing machine. I have problems with the bobbin winder that will only wind it partially full or half full at the most. Any suggestions?
    Problem Solver:
  • 7 Answers
There are two details to this that may make a difference in the answer...
The problem I had was that it wound the bobbins too high on one side, so the rubber foot stopped it but it was only half full. So if you looked at the bobbin after it was wound straight on, you saw a slant to one side where more thread was wound. The fix to that was easy - gently guide the thread down with your finger as it winds to make sure it does so evenly. Be careful with the pressure! You don't need much at all to do the job, but if you push down too far it will quickly go right past the bottom of the bobbin and wind on the metal axel.
The second detail is that the rubber foot that is attached to the right of the bobbin spooler on the top of the machine (it has a screw down on it) has been bumped or moved closer to the bobbin so that it stops too early. The best way to fix this is to tighten the screw just a hair - that goes clockwise and should twist the rubber foot with it as much as you tighten. IF the screw is already really tight, then just use your thumb to push that rubber foot out a bit (again, clockwise around the screw post).
Warning: Overtightening the screw will lead to breaking it all together pretty easily, so only use the tighten the screw method if it's already loose!
Make a small move to it, then try winding again. If the wrapped thread extends past the edge of the bobbin, you've adjusted too far and need to bring it back in.
Posted on Jun 22, 2009
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
How do I thread the bobbin on a singer ingunitity sewing machine
If you go to the Singer site, they generally have the user's manual that you can download for free. It will tell you how to use the bobbin winder. Every sewing machine has the ability to wind a bobbin, but there are several different systems, according to the machine you purchased. Alternatively, you can purchase an inexpensive bobbin winder for under $25 at WalMart online.
Oct 13, 2014 | Singer Sewing Machines
Bobbin winder on singer 1725
Hai, Please change the new bobbin winder. Because bobbin winder and winding is very important.
Mar 20, 2014 | Singer 1725
Singer sewing machinre 301, bobbin winderon right side is worn so bobbin will not fill
I have never been in love with their bobbin winding system anyway; too often, it winds unevenly, which can cause a great many problems. The best approach would be to sidestep the issue and purchase an inexpensive bobbin winder. Sidewinders cost less that $20 at WalMart; you can order online, and if you pick it up at a local WalMart or FedEx facility like Kinko's, there is no charge for shipping. It does a much better job, and you can regulate the tension--you can't do that with a Singer bobbin winder. I know, I have 5 Singer machines!
Jan 19, 2014 | Singer Sewing Machines
We have 2 singer 7442 machines and they will no longer wind the bobbin. Up to this point we followed the instructions the manual gave on how to thread and wind the bobbin. How do we fix?
If you have followed the instructions and the winders do not work, the machines will need to be repaired, or you could purchase a Sidewinder Bobbin Winder and forgo the expense of having the machines repaired.
Mar 08, 2010 | Singer 7442 Mechanical Sewing Machine
Singer 2662 winds bobbin only half full.
there is an adjustment on the bobbin winder. Just bend the little spring flap that rides inside the bobbin while winding. Bend it up a little. The flap being pushed up is what releases the shut off
Jan 05, 2009 | Singer 2662
Bobbin does not fill completely
Machines that stop the bobbin winder automatically when the bobbin is full have a mechanism that detects how much thread is accumulating in the bobbin while it is winding, then stops the winder when the bobbin is full. It is likely that the bobbin winding mechanism needs to be adjusted by a mechanic.
On the other hand, if the thread winds evenly, and stops winding when the bobbin is about 3/4's full each time, you probably don't need to worry about it if all else is good (even tension, consistent stitch quality, and so on).
If you'd like me to post some general troubleshooting tips, let me know.
Good luck
Nov 28, 2008 | Singer Featherweight 132Q Mechanical...
Singer 2662 Logo
153 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
