Question about LG 47LG60 LCD TV
When it first starts it is discolored. Not blurred. After about 15 minutes it returns to normal and works fine.
  • 1,238 Answers
Try to reset all connectors from main board and t-con board.
Posted on Nov 09, 2012
3 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: When starting TV in A.M. the picture fades and
Hi
Try to play the DVD on your TV,if the picture is normal when you play it.The problem could be the signal of you aerial antenna or cable.
Thank you and good luck.
Posted on May 07, 2011
Ecollier2012
  • 3459 Answers
SOURCE: my lg 37 inch lcd
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 09, 2011
2002 mercury grand marquis wont start when engine at normal temperature must wait 15-20 minutes
I have exactly the same problem started last winter, ran fine all summer then as soon as it got below freezing again if I start it and run for 15 20 minutes wont restart I have to let it sit for 20 minutes or so and then it will start again. no codes and just turns over without starting. cant be fuel pump like i said had this problem last winter then ran fine all spring summer and fall! Anybody got the answer for this one??
Mar 09, 2012 | 2002 Mercury Grand Marquis
Lower range will not come up to temp on 'bake' after 2 hours it only got up to 275 o but it got to 450 in 15 minutes on broil. This is a sudden thing as it was fine last night.
either the bake element in the lower oven has what is called a "hot-spot" a discolored area on the element and can no longer pass enough current to heat the oven and will most likely burn out soon,or a thermocouple went bad that senses oven temps,but this bulb in the roof of the oven normally goes bad over a matter of time
Feb 12, 2011 | Maytag MER6872 Gemini Electric Kitchen...
After a cold start, I don't get cabin heat for about 15 minutes. The heat gauge starts at C (cold), rises to normal operating temperature, then rises to just under the H (hot) for about 30 seconds, at...
Check for low coolant, you might also have a sticking thermostat. Alot of fords get air pockets, make sure if it needs coolant to let it run for about 10-15 min with the radiator cap off.
Oct 15, 2010 | 2003 Ford F150 Regular Cab
Problem With KENMARK flat Screen TV - BLACKS OUT
you do not give the model number for a better diagnosis
the most common cause of this problem is the invertor or at worse the screen its self.
If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
Feb 14, 2010 | Zenith IQC50H95W 50" Rear Projection...
2001 Camry Often Won't Start When Hot Outside Unless Jumped
well is the battery draining over the time its sitting?
could be a bad battery or alternator, and/or you might have something on the car constantly draining power from the battery.
best to have it looked at by a mechanic.
Aug 09, 2009 | 1994 Acura Integra
F-150 not idling at cold start up
i am able to help you you need to adjust the idleto a higher level. does it stall or does it run high on start? please email me back at meanness628@aim.com i have iphone so i am always connected with my email, please feel free to email me at any time thankyou.
Jan 08, 2009 | 1997 Ford F150 Regular Cab
LCD screen looks like bad TV reception
if the display returns to normal when you press the bezel at on end means there is a bad connection to the inverter behind the bezel itself or the inverter is ready to give up the ghost.
you can attempt to dismantlethe laptop and remone the lid or in some cases just unscrew the bezel and remove the plastic cover, the inverter is at the bottom of the display you can't miss it
hope this helps
regards
Nov 18, 2008 | Acer Aspire 5601WLMi Notebook
Panasonic Microwave Convection Oven Model NN-8501Vstops after one min. of operation-Display goes to all
If you unplug the ac power cord , wait between 30 and 60 seconds and then replug the cord in, push the reset button and then select the time ot cook desired followed by the start button, it seems to work fine for a while (days) and then for some unknown reason it stops after one minute of operation and returns to all eights on the display. A real mystery as to why this is happening and what is really wromg with the unit.
Jul 25, 2008 | Microwave Ovens
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
LG 47LG60 LCD TV Logo
46 people viewed this question
Computer Repairing
Computer Repairing
