Question about Adobe Photoshop 7.0 for PC
Cannot intalled my Photoshop 7.0 on Vista
When I try to install my Photoshop 7.0 on my new laptop (Vista 64 bit) it give me the following error and will not install; "Could not complete your request because of missing or invalid personalization information."
Can you help me?
  • Anonymous Jan 06, 2009
    i can't help you because i have an error about a datacab1 being corrupt and then it says my system is not compatible, but I have vista as well.
  • Anonymous Jan 07, 2009
    I have the same problem
After Down lord I can Solve this matter
Posted on Jan 07, 2009
Good mornning , i have dell d620 laptop (latitude) and i removed the original vista windows were on it when i bough it and installed windows 7 , i need to know is my laptop model match with window 7 or no...
All the vista drivers can be used for 7. By default, windows 7 installs all drivers except for touchpad.
You can find 32 bit version for it here
The 64 bit of Windows 7 64-bit ALPS touchpad driver from the Dell support site for a Latitude E6410 is reported to also work for D620. Give it a try.
May 11, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a new dell laptop with vista and cannot install itunes - it freezes and comes up with an error message.
What does the error message say? Post the exact contents here.
Just in case, check to see if your computer is 32-bit or 64-bit by going to computer properties. Make sure you got the correct version of iTunes for your computer.
Check this Apple support page for more information.
May 05, 2011 | Apple iTunes
I have a problem in downloading sound driver for window7
There are no officially supported Windows 7 drivers for the Acer Aspire 5570 notebook. However, the Vista drivers should work just fine.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Regardless of whether you have 32 bit or 64 bit Windows 7 follow these instructions:
1. Go ahead and download 32 bit Windows Vista drivers by following the link: Acer Aspire 5570 Audio Drivers
2. Save file to the Desktop for easy access.
3. Extract ZIP file to Desktop.
4. Open the extracted folder.
5. Right click on the file "Setup" and select "Properties".
6. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows Vista (Service Pack 2)". Click OK.
7. Double click the "Setup" file to run the installer. If the installer completes, then restart the computer and play a music file to see if you have sound.
If the installer fails, then follow the next set of directions:
1. Press Win+R to open Run command.
2. Type "DEVMGMT.MSC" and press enter.
3. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "Multimedia Audio Controller".
4. Right click on the device that has a yellow exclamation point next to it and select Properties.
5. Click the Driver tab and select Update Driver.
6. Click "Browse my computer for driver software".
7. Select "Browse...".
8. Browse to the extracted folder and select the "Vista" folder if you have the 32 bit version of Windows. If you have the 64 bit version of Windows, then select the "Vista64" folder. If Windows tells you there are no compatible drivers after step 9, then select the WDM folder and repeat step 9.
9. Click OK and then click Next.
10. Ignore all errors that Windows may give you and install the driver, restart the computer, and try to play a music file.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
Just got a toshiba laptop with windows 7. When trying to install my ricoh sp210sf printer/scanner/fax on my laptop. I get an error message mid way through which says intaller has stopped working. I have...
Please verify if you have Windows 7 32 bits or 64 bits, then download and try again
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/spc210/spc210en.htm#Microsoft Windows 7
Regards,
Mar 13, 2011 | Office Equipment & Supplies
I intalled windows 7 64 bit on my laptop and when I try to download the drivers from Lexmark, the printer isn't available. I also can't connect through wireless. Can you help me?
What is the status of the wifi light on the printer? orange or green? blinking or steady? For the Lexmark X4650 Windows 7 64-bit driver, click on this link Lexmark X4650 driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software. Thanks.
Jan 03, 2011 | Lexmark X4650 InkJet Printer
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop 7.0 for PC Logo
361 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
