Question about Philips SPC 200NC Webcam
Harware incampatibility I recently bought a Philips SPC 200NC webcam. According to the box, my computer has all the requirements to run the webcam, and most of the time it works fine. Then I get the dreaded blue screen that says there is a problem with recently installed hardware and shits my computer down. I have tried to look and see if there are any additional software updates to assist with this problem but have not located any yet. Right now I must keep my webcam unplugged from my computer to keep it from causing problems. Is there anything else I can do??
  • 2,961 Answers
Re: harware incampatibility
Issues with web cams like you have effect notebooks and desktops alike, because sometimes there is not enough power supplied to the usb port that the cam is connected to. Trying a different port can sometimes cure this, but also check with the phillips web site for any updated drivers or uninstall and reinstall the driver and software again as the blue screen can also be because of a corrupt driver.
Posted on May 24, 2007
0 characters
3 Points
I need driver of spc 200nc.
hi go in this link and download your driver ...dont forget to choose yor operating system before download.
Dec 13, 2010 | Philips SPC 200NC Webcam
I`ve lost my intallation-cd... is it any way for me to install the cam now??
though i need to know the os u r using..
considering that u r using win xp or vista..
howevr, along wid the company, there will b a list of such site n driverdownload links if u search by the model name on a search engine likegoogle..
download them onto a location; if the driver is in a zipformat, unzip it,if itz in .exe form, just run it; if done manually it'llask for the correct driver and location; relocate the path and a.inffile (wat it'll ask for)..
try downloading..
win xp:
win vista:
but always better to consult ur system admin/vendor....
Nov 05, 2009 | Philips SPC 200NC Webcam
Cannot download driver for webcam philpsSPC325c/27
Is the reference you require. yours is the "c" version but according to my checks the "nc" will work.
select your os etc and download
It is by webcam standards quite an old model but the drivers support all the way up to vista.
Aug 22, 2009 | Philips SPC 200NC Webcam
My webcam PHILIPS SPC 220NC can't connect to video capture device.
steven lamont moore "the reason could be is that it is busy loading on another program
steven lamont moore
Mar 01, 2009 | Philips SPC 200NC Webcam
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Philips SPC 200NC Webcam
I lost my cd to y philips web cam
copy and paste all of the above into address bar contains driver for your webcam but is not for vista no drivers for vista
Jul 23, 2008 | Philips SPC 200NC Webcam
Web cam problem philips
i do not have the setup of Philip spc 200 nc personal web camera. can you send it to me. help please.gona
Dec 27, 2007 | Philips SPC 200NC Webcam
Web cam
I have found a manual and driver at the links below
Aug 19, 2007 | Philips SPC 200NC Webcam
Philips SPC 200NC Webcam Logo
88 people viewed this question
Top Philips Webcams Experts
micky dee
Neville Vyland
Neville Vyland
Larry Maranto
Are you a Philips Webcam Expert? Answer questions, earn points and help others
