SOURCE: I have a 1995 Polaris Big Boss 6x6, and I can't
they can be trickey, but since you have the part in your hand, you could take it to a small engine repair shop and will cost very little to repair
SOURCE: 1992 polaris trail boss 4x4 not engaging
replace button under the high and low lable on the shifter..... the shifter automaticaly pushes these buttons when put into gear
SOURCE: I have a Polaris Big Boss 4x6 model no W928627,
in a quad the tenth number is the yearif 2000 or before its a letter.not sure if 4x6 are the ssame.hope this helps alittle
SOURCE: Where are the cam timing marks on a polaris magnum 1998
There will be a couple sets of timing marks for your cam. The first and probably most important is the mark on the flywheel. On the top of the recoil cover, there is a bolt that can be removed to see the timing mark on the flywheel. The mark on the flywheel will be a "T". You will notice that the threads where the bolt was removed will have a point, kind of like an arrow that the "T" needs to be lined up with. Next there should be 2 dots on the camshaft gear. If the "T" is in the window, the dots should be at the top of the gear, and the piston should be at top dead center. The camshaft lobes will also be facing away from the valves. Hope this helps, Daniel.
