Question about Oreck XL Ultra Bagged Upright Vacuum
The bearings on the fan side of the motor were extremely bound. I was able to free them up with WD 40. Should I pack the bearings with grease?
  • Oreck Master
  • 18,392 Answers
The bearing on electric motors are normally sealed bearings so no dust or dirt can get into them, if i were you while you have the motor out i would get new ones the number will be on the side of the bearing and are very cheap to buy,
Posted on Nov 09, 2012
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 20 Answers
SOURCE: Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Posted on Mar 27, 2009
  • 206 Answers
SOURCE: oreck xl 9100 bag wont stay on
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Posted on Jul 30, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
A hoover uh70400bca the bottom brush stopped turning the belt is good
dont know that model but usually the brush roll clips into the front
and comes out wuth a firm pull. the metal ends on mine unscrew
usually hair, cotton, etc packed in round bearing, clean up spray with WD 40 and grease the bearings.......jobs a good 'un
Dec 22, 2014 | Hoover Vacuums
I have vax 1800 pet vacuum. It is picking up fine but very noisy. I have replaced the belt in the past and the noise started then. On looking at it closely today I noticed brushbar was getting worn where...
spray the end of the brush-bar were the bearings are with WD-40 if that solves the problem replace the bearing when it starts screeching..
Jan 19, 2013 | Vacuums
The powerhead on my Dirt Devil keeps cutting out, and after a few minutes, making a burning rubber smell. Only used it less than a dozen times (same thing happened with my Hoover!) It is free of hair...
Sounds like you've done a lot of troubleshooting on this unit. It could be that the bushings are worn and the "play" in them is causing them to seize (this is often accompanied by a chattering sound from the bushings).
I would suggest lubricating the bushings & axles with WD-40 to clean them out and then put machine oil on them or maybe even something akin to wheel bearing grease.
Only time I've seen this symptom where carpet seems to be "destroying" vacuum cleaners is when the carpet is used for pet bedding.
Maybe there's carpet cleaner residue which is oxidizing ("rusting") the bushings.
Charlie
Feb 26, 2011 | Vacuums
The beater bar quick working.
Remove the bottom plate and take out the beater bar plus the drive belt. Inspect the drive belt for burn marks or other damage. The bar itself is usually bound up at the bearings on each end with string, hair, and thread. Pull the bearings off, then clean the pin ends and interiors of the fixed bearings with a Q-tip and some WD-40. Oil the bearings lightly with 3-1, or similar, then reassemble the bar as it was before using a new belt if required. This process is required from time to time as the debris accumulates through use. Hope this helps!
Oct 22, 2010 | Dyson Vacuums
Kenmore progressive 300 smells like it is burning
These vacs use Ametek motors which are practically designed to fail. Frequent complaints are a burning smell and louder than usual noise in the canister. The problem is the poor quality
bearings Ametek uses in the motors in the units. They have low-end ball bearings with a nylon "crown" that breaks up and gums up the bearing. Further the fan end of the motor is a bear to get to because of poor (intentionally?) design. With great difficulty I WAS able to remove the fan and housing and inspect the bearing. Since finding a replacement is too much trouble or impossible, I cleaned up the ball bearings and switched the bearings on the two ends moving the remaining good one from the brush end to the fan end where I assume the load is. I packed the damaged one with grease.
Now the motor runs smoothly. I doubt however this jury rig will last very long. It is very irritating to toss a $120 motor because of a failed bearing. Kenmore and Ametek should be embarassed but I'm sure they are NOT!
Jul 15, 2009 | Oreck XL2200 Bagged Upright Vacuum
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Jan 15, 2009 | Kenmore 22313 Bagged Canister Vacuum
Brushes not turning, but suction okay?
My problem was that the metal "transmission" had it's upper and lower bearings frozen. I sprayed WD-40 and let it sit for awhile. I then proceeded to work it free. It was quite rusty inside the cover plate, leading me to believe that water somehow entered the housing or they used a water based lubricant from the factory. Water based lubricants are generally cheaper than oil based so I'm tending to lead that way. The "transmission" is the metal rod with hypoid type gear in it that turns the 2 plastic gears. It is a press fit to the turbine wheel, so twisting a flat blade screwdriver under the turbine wheel will remove it. Make sure the lower bearing is free to turn easily. I also used some anti-sieze compound on the gears.
Aug 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Oreck xl9300
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=767429
Oreck XL9300
Posted by Cubfan70 on July 10, 2008
Bought a new motor but can’t figure how to pull off the metal fan from the old motor. Is it muscle or a trick?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Oreck fan is generally held on by a nut on the end of the motor and is replaceable, and it usually slides on but over the years it tends to stick on the shaft so you can take like 2 screwdrivers – one on each side and try to lift gently and the fan should come off, if not try some WD-40, and look on the inside of the new fan to see if there are threads that might screw on, if not then it should just side on, make sure if you use WD-40 to wipe off any excess liquid. Check you owner’s guide in the back pocket of the Oreck XL9300 to see any instructions that they might have, or call the Oreck factory to get a new owner’s manual for the vacuum.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
52 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
