Owners Manual for Aussie Air conditioner, Model n13174
Model Number N13174 ASW-H12A4/EJ-2
2 Suggested Answers
  • 56 Answers
SOURCE: Need a manual for Fijita N13174 Air conditioner
Yes if the unit is not outdated by manufacture. Try googleing the manufacture.
Posted on Feb 12, 2009
My aircondition shows f6 error code starts outdor unit for few seconds and stops. Vox asw-h12a4/qb
Hi Marija, F6 error code is....I hope this helps.................CHEERS..
1?Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 08, 2016 | Heating & Cooling
The air hose on my Aussie Air N13174 portable air conditioner is broken. Where can I buy hose replacement?
take a pieceof the old hoe with you and go to a hardware store and have them cut you a new piece.
Jan 23, 2015 | Heating & Cooling
Daijitsu n13174
Check to see if you have the right outlet and plug. You should have no problem wiring it,fairly easy task! Make sure you have the right voltage parts!
Jan 14, 2014 | Heating & Cooling
Fujita remote control code for air conditioner model ASW-H12A4/HS
06,03,09,01 are the codes to check. If you wish to get more, check these links. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Selecting the view option, either to Mosaic / Timeslide, can be selected by the dropdown list, at the top left of the display window, it will make surf easy.
Oct 09, 2013 | GE JASRM24912 Remote Control
We have just installed our 1.5kw split system model no: ASW-H12A4/SQCR1DIAU - error message comes up as E5
E5 Outdoor activation of compressor over heatprotection or motor lock
or E5Communication error between outdoor and indoor.
Please check input of out door unit and contacor coil energized. if no power input correct it. If no power in contator coil, mat be the problem PcB thermostat command. Check your setting is 23 dgree and less than that and also mode in "Heat".
Dec 16, 2010 | Heating & Cooling
Anyone have a Fujita Installation manual
it should be all coded on the head and compreser for the sparky
Dec 17, 2009 | Heating & Cooling
Fujita V-Lec Air con
i need a window kit for my air con
Jul 04, 2009 | Heating & Cooling
Lost Operation Manual
I was unable to locate your particular owners manual but click the link below and double check your model numbers. Also there is contact info so you can call to get more information if it is necessary.
http://www.fujitsugeneral.com/owners_manuals.htm
Mar 22, 2009 | Heating & Cooling
Feb 06, 2009 | Heating & Cooling
Heating & Cooling Logo
328 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
