Question about Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook
My volume dosen't work anymore all it says is no audio output device is installed
  • Dell Master
  • 7,627 Answers
Install audio drivers, Has the OS been upgraded? Start by looking here: http://www.dell.com/support/drivers/us/en/04/Product/latitude-d610. You can go to device manager and run a scan for hardware changes. reboot and try again to scan for hardware changes. Without your OS I cannot give you a more percise solution. If you find this helpful check the solution box
Posted on Nov 09, 2012
  • 79 Answers
SOURCE: sound system
Go to Dell's website and download the audio driver for this model, then install the driver, all the istructions will be on the website on how to istall this driver, quite simple...
Posted on May 25, 2009
SOURCE: how can i fix audio output device on inspiron E1505?
on the bottom right hand corner of your computer where the time is you should see a little speaker do you see it ok now click on it and there should be a little bar that you can pull up and down and there should be a button that says MUTE either its on mute or either bar was all the way down
Posted on Jun 16, 2009
  • 1019 Answers
SOURCE: the volume won't work anymore, it says the audio
it,s saying the audio Device used by this Application ( Program )
Is not detected.
The problem most likely is with the program i.e media-Player, Cyberlink Power DVD Et,c.
uninstall and re-install your Audio/Music Application.
Also check the devices/Drivers are not corrupt or not installed.
Mike @ Compurepair,
Posted on Nov 05, 2009
  • 24 Answers
SOURCE: the volume wont work
Hello Friend, There is a sound driver problem in your laptop. Install a sound driver from a driver CD given by manufacturer if it is not provided then go to the manufacturers web site n download drivers then install it. After install restart your PC n check for sound.
Hope this may solve your problem reply n vote as early as possible...
Posted on Jul 07, 2010
  • 116 Answers
SOURCE: can you please help me? there's an prompt that
HI. Welcome to Fixya.
You can check first the device manager just type it in the start search. There is possibility that the audio driver is gone. Try this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid= Try to restart the laptop. Hope this resolved your issue.
Thanks for contacting Fixya. Bye for now.
Posted on Jul 16, 2011
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
I cant hear sound from my computer
If you are using speakers on a desktop computer, the first thing to try is to test your speakers on a different computer. If they still don;'t work, then it's time to replace them. If they do, then there a few things to do.
You would first have to test the speakers on a different audio port & see if that makes a difference. If it still doesn't work, the next few steps will also apply if you are using a notebook.
Check to make sure that the volume is all the way up and NOT set to mute.
After making any adjustments to the volume, try playing any media file & see if the media player volume is also correctly set (cranked up, NOT muted).
(*) In the event that it comes up with an error, read it: it might say something about not having a sound device installed. If it does, then you will have to download the audio drivers from the Manufacturer's website (You will need to type in you computer's Service Tag in the website to skip to the downloads page where you would look for the Audio Drivers category); if not, see below.
If you have Windows Vista or Seven with either HD audio or HDMI-capable display, right-click on the volume icon near the system clock and choose Playback Devices.
Something like this should come up:
Make sure to select the CORRECT DEVICE. If your computer is connected to an HDTV, choose HDMI. If it's a notebook computer, choose Digital Output. Otherwise, select SPEAKERS as seen above.
If all else fails, you will have to uninstall then re-install the sound drivers.
In Windows 7 or Vista, click on start & type "Device Manager" in the Start Search box and click on the Device Manager icon that appears in the results list
For Windows XP, Click on Start -> Control Panel -> System.
The System Properties window pops up; click on the "Hardware" tab then click on "Device Manager"
In the Device Manager window, open the Sound, video and game controllers.
Right-click on your audio device and choose "Uninstall"
When prompted, restart your computer. It should work after that. If it does not, it will provide an error message that will determine the actual cause of the problem. You may end up downloading the drivers as detailed in the (*) section above.
If the drivers will NOT install and says there is no compatible hardware, then the audio device has stopped working & will need to be replaced. Any other error would pertain to the operating system and would be a completely different issue.
Aug 25, 2011 | Dell Computers & Internet
I dont have sound in my pc.i dont know where to fix my problem
If you sue external speakers or headphones, follow these instructions. If you have a notebook computer & are using the onboard speakers, skip to the *Windows section below.
You can start by checking your speakers, if any. Make sure they are powered on and functional. You may also want to test there speakers on a different computer just to make sure.
If the speakers work on a different computer but YOURS still does not have sound, try a known-working set of headphones. Make sure the jack is seated correctly as it may be loose.
*Windows:
Check the volume controls on in Windows. If windows does not have any volume controls, then chances are, the sound drivers are not installed. Check your computer manual to find out what model it is, then visit the manufacturer's website to download the appropriate drivers and software for the sound card.
Note that if you have used external speakers or headphones anytime before this issue started, you may have to re-plug the device & unplug it again & allow Windows to detect that it's unplugged (for HD-capable audio devices in Windows Vista or 7).
If you do have HD audio in Windows Vista or 7, right-click on the volume control in the notification tray on the bottom-right corner of your screen and select "Playback devices"...
... then make sure you choose the appropriate output device (whatever it is that you actually use: Speakers, headphones, HDTV output, etc).
Aug 12, 2011 | Computers & Internet
Have only realtec audia manager but can find my normal volume botton anymore on my home pc
Hi Tania,
This problem is a 'bug' in Windows XP operating system.
Follow these steps to restore your volume button:
  • Click on 'start' & select 'Control panel' from the menu.
  • Look for the icon named 'sound' in your control panel & click on this icon to open sound properties.
  • Look for the check box with the words: "Show volume control in task bar"
  • Remove the check from the check box & click on the "apply" button at the bottom right of the properties window.
  • Now click on the check box once more to add the check once again.
  • Apply the change by clicking "Ok" at the bottom of the properties window.
Your volume control should now be visible once again in your task bar.
Don't hesitate to respond should you have any further queries.
Best wishes,
Graemevm
May 28, 2011 | Microsoft Windows XP Home Edition
No audio output device installd
You need to install the driver for your laptop's audio output device.
We'll need to know your laptop make and model before providing links to the correct driver
May 19, 2011 | Computers & Internet
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
