Question about Dell Inspiron 531s Desktop Computer
How does P4 Connector connect to the CD Rom Drive
  • Dell Master
  • 5,660 Answers
Hmmm, P4 is usually a designation, for a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
I see though that they have P2 as the 4-pin ATX +12 Volt power cable, and P4 as a SMALL 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
This type of power cable is used on a Floppy Drive, or a Card Reader.
Not a Harddrive, or Optical Drive. (CD/DVD drive)
The Standard 4-pin Peripheral power cable, is used on an IDE (PATA) harddrive, or optical drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Rounder corners on the Top of the plug connector.
Only plugs in, in one direction.
Owner's Manual > Page 109 -
Power Supply DC Connector Pin Assignments
P1 = 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
P2 shown above - 4-pin ATX +12 Volt power cable
P3, P5, and P6 are SATA power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
If you have a SATA optical drive (CD/DVD drive), the above is the power cable used.
Uses a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
SATA data cable connector on motherboard, is shown below the SATA data cable.
NOTE*
Color does NOT matter
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 09, 2012
Install cd rom
Looking at the motherboard as it is installed in your computer case;
Processor to the Top, Ram Memory slots to the Right, White long PCI slots (2) to the Bottom;
Below the left corner of the Processor socket, is the connector on the motherboard for a Floppy Drive cable.
To the left of this connector, is the connector on the motherboard for the 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Below the left corner of this connector is a small rectangular female connector. CD1
This is where the audio cable from your optical drive (CD/DVD drive) connects to.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=272&CategoryID=1&MenuID=18&LanID=0
Scroll up a little, click on Manual. (Driver/ BIOS/ Manual)
Go to the BOTTOM of the next page, and click on the country nearest yours.
[ English manual for P4VMM2 PCB 3.2A ]
This is a Zip file. If you do not know how to open a zip file, once you have downloaded it, post back in a Comment.
Would appreciate hearing back from you.
Regards,
joecoolvette
Jul 08, 2012 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When u put a new cd rom in where does the wire go 2
It depends on the CD-ROM you will install. But by default the cd/dvd-rom of this computer is connected via SATA connector and is plugged into one of the 4 SATA ports in the motherboard.
Thank you for visiting FixYa!
May 13, 2011 | IBM THINGPAD 600 SERIES 13.3 TFT LCD...
I am unable to connect a cd rom from an old pc to my new emachines because there is no "ribbon" to connect the cd to? How else can I connect it to the motherboard? The CD doesn't have a SATA...
Look on the mother board for a ribbon connector.. double row of pins.. Some boards will have a legacy connector. If not.. you can buy an adaptor to connect IDE CD to board,
BUT.. for about the same cost, you can buy a cheap new CD-DVD RW - burner.. probably with far better peformance than an old one. About $25 should do it.
Dec 13, 2010 | E-Machines emachines (emachinees) CD-ROM...
I need to know what order to put the wires from the mother Bord to the floppy drive to the cd Rom\burner to the hard drives
The floppy drive has it own data cable and does not connect to the same cable as the hard drive and CD ROM/R-W drive.
If the hard drive and CD drive are IDE devices, then the hard drive should be the connected to the connector at the end of the IDE cable and the jumper on the hard drive set to Master. The CD drive should be connected to the middle connector and its jumper set to Slave. The other end connector should be connected to the Primary IDE connector on the motherboard.
Nov 11, 2010 | Intel Computers & Internet
MY ROM is a Sony (DDU1632C1) Internal DVD Drive. It doesn't read the DVDs and the CDs. I checked the data cable from the mother board and the power cable, cables worked for my CD rom but not the DVD/CD...
Check On the Back Off Your DVD-Rom itself look little pin with a black connector like a mini bridge... Look if it on position Master If So change your little connector to Slave Position.. The Restart your PC... Check also your IDE Cable for defect and all the pin inside your DVD connection ...Good Luck
Oct 09, 2010 | Sony (DDU1632C1) Internal DVD Drive
Hi there, i have a problem with my motherboard. I bouth it second hand with P4 CPU and Power suply, when i plug it into my computer it reads the hdd and dvd-rom and thats it, staing like this all day. When...
Check The RAM ( Memory )
also that the DVD And Hard-Drive jumper settings, are correct. i.e Hard-Disk set As Slave. DVD/CD ROM SET As Master ( if on the same IDE Connector/Cable ) Also insert your operating system Disk, In The CD?DVD Drive.
Mike @ Compurepair.
Nov 04, 2009 | ASUS P5S800-VM Motherboard
My motherboard doesnt have that long prong connector for the cd rom drive so how do i connect the cd rom drive?
What you will going to do is find a nearest computer store in your place and buy the connector for your cd rom drive.
Oct 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Dell Inspiron 531s Desktop Computer   Logo
134 people viewed this question
Alun Cox
