Component blown up from the electronic control card.
The whasing machine only gets water for about 30 seconds. Then stops and the program light starts to blink (as when the program is finish). After exhaustive checking of other posible sources of the problem, I've found that the electronic control card has a missing component like if it is blown away due to some overcharge or whatever. The component has to be a capacitor, as the "C" is what the card shows in its position ("C7"). The card has these indications on the front part: ST-01 94V-0 E310229 and these others on the back side: MINIQCP E www.elmarc.com 120400063 Any idea how I can identify the capacitor in order to replace it?
5 Suggested Answers
adib
  • 450 Answers
SOURCE: critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
Posted on Sep 11, 2005
SOURCE: remote problem
You get lucky once in while right?-lol
You need to do 1 of 2
get universal remont-are use the 2 you have but be sure you enter the source button on both-
Posted on Oct 21, 2007
IrishDruid
  • 2712 Answers
SOURCE: RM-VL900 System Control won't program anymore.
Hello drumrunner,
Maybe THIS link may provide some assistance..
Cheers!
IrishDruid
Posted on May 11, 2008
  • 899 Answers
SOURCE: component input- no audio/video signal
copy protect circut may be going bad or the component cicut has now failed
Posted on Oct 07, 2008
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Whasing machine boils on all programs
sounds like a thermostat problem not cutting off the heater when selected temperature is reached
Feb 09, 2013 | Indesit Washing Machines
Not spin
problem with motor control board
Jul 08, 2012 | Frigidaire ATF6000ES Front Load Washer
Have a kenmore elite he3 which stops the cycle w/ 40 min. remaining and flashes back and forth the 2 initials ''F'' and ''H'' on the screen. Don't have a manual to check
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display.
  1. Unplug the washer from its electrical source and wait for 30 seconds.
  2. Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
  3. The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
  1. Check all hose connection and valves, both hot and cold, are turned on completely.
  2. Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
DrakeTech
Feb 23, 2010 | Washing Machines
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
Child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Washing Machines
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
