Question about Microsoft Windows XP Home Edition Service Pack 3 Full Version OEM for PC
Samsung dvd 616e driver is missing - Microsoft Windows XP Home Edition Service Pack 3 Full Version OEM for PC
  • Microsoft Master
  • 2,878 Answers
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Posted on Nov 09, 2012
I am unable to write cd with samsung 616e combo drive
Hi likeme2299
Unless you would succeed with other cd's from another manufacturer or updating the firmware , your drive is defective and is probably not worth reparing .
Best regards ,
fanaudi .
Sep 12, 2011 | Samsung SD 616E (729507925578) Internal...
Hi am trying to download my drivers for my samsung dvd master 16e the model num is sd-616 but i cant find them anywere my p.c is on xp
Go to www.samsung.com and after selecting your country select the kind of product and the exact model number. Then select the Support option. Here you will find the drivers for it.
Aug 07, 2011 | Computers & Internet
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
I am trying to install windows 7. I get to the
try selecting custom installation instead of upgrade. if same error occur there's a problem in your windows 7 cd. some of the files inside is corrupted
Mar 28, 2010 | Samsung SD 616E (729507925578) Internal...
Windows cannot load the device driver
you need to right click on the device, from the view with the yellow triangle, and update the driver or roll back the driver.
failing that , download driver max and it will find the driver for you.
Sep 24, 2009 | Samsung SD 616T Internal DVD Drive
Media player says that it cant find the burner
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Dec 31, 2008 | Samsung SD 616E (729507925578) Internal...
Samsung dvd-rom 616E won't play sounds
I decided to check to see which video player programs were already on my computer. I have a Dell, so there were several that came preinstalled.
Did I mention that Windows Update had installed several new fixes recently?
My toolbar no longer worked like it did last week, that was a clue.
2 of my programs were no longer in the programs list, Interplayer and Power DVD were missing.
I went to the Power DVD site and downloaded the latest update.
Now my DVD player works fine.
I don't know why RealPlayer or Media Player didn't work, even with the updates.
I don't care, as long as something works.
I could have tried Winamp too but Power DVD worked and I didn't try anything else after that.
It doesn't have to be a problem with the hardware, but could be the software.
Nov 23, 2008 | Samsung SD 616E (729507925578) Internal...
DVD/CD - RW Combo Drives
Any brand should work as long as you have the correct drivers.
Either IDE (internal) or USB (external) will work.
May 02, 2008 | Computers & Internet
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Samsung SD616e internal dvd
I could have you try a bunch of stuff and go through a bunch of hoop and hurdles but seeing how cheap DVD drives are today it is just less hassle to just replace it with a new one. Really easy to do. Seeing as how you know how to install and remove drivers and all.
Jun 28, 2007 | Samsung SD 616E (729507925578) Internal...
Microsoft Windows XP Home Edition Service Pack 3  Full Version OEM for PC  Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
