Question about Kenmore Dryers
110-6062290 no power
I changed the power cord cuz it wasn't working. electrician said it was my cord. i replaced the cord and it still won't turn on? help!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Have you checked to see if any of the breakers have thrown?
Posted on Nov 09, 2012
4 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Hello,
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. The thermal fuse is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Posted on Aug 06, 2011
  • 88 Answers
SOURCE: I have a kenmore elite
Bad door switch
Posted on Aug 16, 2011
SOURCE: I have power & the timer still works.... But the
check and make sure both breakers in fuse box are still on if they are then look for abstruction where door closes
Posted on Sep 08, 2012
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
How do I find the power board in a 1997 big screen Sony TV to check the fuse? How do I check the fuse? I live in a house built in the 1890's, and last year there were 2 different tornados ,within 2...
With it unplugged remove the rear cover and follow the power cord inside the set to the power supply board===the cord goes directly to the line fuse which in a set of that age will be in a plug in holder----look to see if strand of metal in middle is broken or even blackened.
Amperage will be marked on end of such a fuse--my guess is 6.3 amps but there will also be a marking on the board with the value.
May 24, 2012 | Sony Televison & Video
1995 dodge stratus which has a 2.0L in it won't start. So I checked the fuel pump to see if it was working and it wasn't. Than i figured it out it wasn't getting no power to the rear of the...
Seems to me you have a short to ground what you can do is unplug the fuel pump connector then replace the fuse to see if it still blows if it does not then you need to replace the fuel pump and sender if it does blow then you will need to trce the wire back to the fuse panel to see where it is shorted ....
Oct 19, 2011 | 1995 Dodge Stratus
Kenwood kac-9104d stopped working was in car music loud amp stoped worked I stop to change fuse it wasn't blown popped hood that amp was blown don't know what's wrong with it
Turn your gain below half. Make sure you have a solid ground, not a seat belt bolt. The fuse blew to protect the vehicle because there was too much power being pulled by the amp, possibly from overheating.
Sep 19, 2011 | Car Audio & Video
I need a 240 volt power cord and foot pedal for an Elna Lotus sewing machine. Thanks
try sewingpartsonline.com & look for the elna name & then look for your model number, it wasn't posted, so I couldn't look it up. but the have a lot of model of elna's...
if they don't carry your model check with sewvacdoctor.com & ask them about the part
also could check on ebay
Sep 07, 2011 | Elna Sewing Machines
Hello, I have an older Fridgiaire dryer ( approx 10 yrs ) tha tjsut stopped working. It doesn't even click when I turn the on toggle. I checked the door switch and it's working, there...
Kevin
Aug 06, 2011 | Dryers
Power to cord but test light does not and reset button does not work
this is one of the rare times a gfi should be change out ...if your sure the receptacle has power change it ...you can go to home depot and buy a gfi 20 amp wall switch and replace about 10 dollars ...take the bad gfi out ...if your unsure how to to do this hire a electrician or you can buy a replacement cord with gfi like you currently have for 95 dollars and change it your self goodluck www.dollarspa.com
Dec 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
