Question about Honda/acura Immobilizer Bypass for Remote Start
Resetting a Scorpion alarm fob
We have changed the battery in the key fob for the alarm on the van and we know there is a sequence to press to reset the fobor synchronise it to the alarm but ahve lost the instructions given us a while ago. We have tried all the combinations we can but still no luck. Have downloaded instructions from the website and followed them to the letter and still nothing. Is there anyone who has any knowledge of how to resynch/reset the fob
    Problem Solver:
  • 4 Answers
Try pressinig the buttons at the same time it worked for mine altho mine was for a celica
Posted on Apr 16, 2009
    Problem Solver:
  • 9 Answers
Not sure if this is it for your particualar model but this is how it is for all my cars take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again hope this helps dont hesitate to ask if you have anymore problems or if this does not work pleases tell me and ill see what i can find
Posted on Jan 06, 2009
My alarm goes off intermittently
Try resetting the alarm, using the instructions given at the link below. I'll also copy the text here.
  1. Insert the ignition/door key in the door lock on the driver's- side door of your Mountaineer.
  2. Turn the key to the lock position.
  3. Turn your key to the unlock position.
  4. Turn your key to the lock position.
  5. Turn your key to the unlock position. Your alarm is now disabled. If your key fob works, you can also press the unlock or alarm-disable button on the fob.
  6. Start the Mountaineer's engine and allow the vehicle to run for at least 10 minutes. This will allow the alarm to relearn the default settings. You must make sure that you have disabled the alarm first, however, before you attempt to start the vehicle, so that the alarm will reset itself.
If these instructions don't work, you can try resetting the car's computer by unplugging the battery for half an hour. However, that will reset the keyless entry code, as you can see in the fixya article I link to at the bottom
Jun 10, 2015 | 2003 Mercury Mountaineer
CL220, fob wont open doors I can't get in the car, does this mean the battery is flat?
battery may be flat in the fob or the vehicle has forgotten the code for the fob. and will need resetting. change the battery use the key to open the door put key in the ignition. ( fob Ir old type leave fob off the key) turn to number 2 and press fob till doors lock and unlock. then its reset. dont be worried if the alarm goes off while doing this it will go off when the code is restored. if you have 2 fobs you will need to rest that one to.
Mar 17, 2014 | Mercedes-Benz C-Class Cars & Trucks
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
I have a META M357T bike alarm that will not switch off. I have tried both fobs and replaced the batteries and tried these in both fobs. It was okay 2 weeks ago!
See dealer, there is a sequence you must go thru to reset your pushing turn signal left then right then both twice at same time...It should be something of this type to reset alarm/fob????
Mar 24, 2010 | 2001 Yamaha YZF-R1
My Alarm on my Sportser isnt working. What can I do to fix it?
OK, I assume you have a stock Harley alarm...First try resetting the alarm. Hold the key fob button down (10-20 seconds)until the lights flash. Sometimes they get out of sync if the fob button gets pressed too many times in your pocket. Then try normal operation. 1 long press sets it, and 2 quick presses disarms.
Oct 15, 2009 | 2007 Harley Davidson XL 883 Sportster
Security system FOB inactive, battery good, no pin. Need to disarm. What can we try next?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
With the fob present, turn IGN switch:
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Sep 05, 2009 | Harley Davidson FLSTFI Fat Boy Motorcycles
I having issues with my 02 standard softail. the factory alarm seems not be reseting. i can get the bike to start but then dies out on me. then I struggle to get it back on. anyone know how to reset...
The fob may have fallen out of sync with the alarm. Press the key fob button for 20 seconds and they try arming and disarming the alarm. If that doesn't work you will have to re-set the alarm. A battery disconnect can cause this problem. Look in your owner's manual for alarm re-set procedures.
Jul 16, 2009 | 2000 Harley Davidson FLSTC Heritage...
Battery dead after sitting too long, after battery is charged, security light comes on and car will not crank... Is there a sequence that needs to be followed in order to reset the theif security on this...
lock and unlock the doors with the key fob this usually resets the alarm. If the key fob doesnt work there is a procedure for resetting the system. But I can't remember off the top of my head but the owners manual does tell you how
Jun 21, 2009 | 2000 Cadillac DeVille
Honda/acura Immobilizer Bypass for Remote Start Logo
1,062 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
