Question about Dymo DateMark Date/Time Stamper
My Dymo DateMark prints off the wall things at random.
One minute it will print 01-08-09A11:35 RCVD which is correct, the next piece of paper will be stamped with 01-05-09A11:35 CEDL or 2 16 1 R22-069CEDL or 22792-C33 280EFLE. Whats wrong with this thing?
  • bowermanj Mar 09, 2009
    I have the same exact problem. This thing is waaaayyyy OVERPRICED for the performance I have gotten. always end up with a mucked up document because it prints random stuff and not what I have set it for
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: dymo datemark
open the back cover where the batteries are and press the pinter reset button
Posted on Nov 05, 2008
SOURCE: Dymo stamps doesn't see USB Dymo scale
I connected my 10lb USB scale directly to the PC port bypassing a hub.
it worked fine!
Posted on Apr 21, 2009
komguy
  • 2306 Answers
SOURCE: How do I reink the Dymo DateMark Stamp
You have to remove the ink roll door, on the front left near the bottom. Pull the roller out with a tweezers, add a few drops of ink to the roll and re-install. No matter how careful you are, you will get some ink on your hands...
Posted on Jun 22, 2009
komguy
  • 2306 Answers
SOURCE: my dymo datemark stamp says
To reset you press a toothpick in the little hole on the left side in the back. If you have more errors, you can go to the dymo website and download the manual and see troubleshooting tips.
Posted on Jan 28, 2010
My dymo datemark stamper is printing crazy. i have it set for RCVD. and i get 11-23907P00921Pain or 11:12895 A27038-PMI and other things. i tried taking out the batteries to reset the memory and also...
Mine was printing crazy also.
A couple of months a go a tiny tiny spring was on my desk, I saved it and what do you know it came from inside the stamper.
I removed the all the batteries and then removed the five screws in the back, opened and inspected.
The spring was from inside. The black piece of plastic that moves along the belt, on the right side of the that piece there were two little noggles one white and one black. Threaded the spring back in place and cleaned the little plunger space, so it would go up and down smoothly. Replaced the back, screws then the batteries and it is working better than when it was new.
I bet the spring came off in shipping, because I was really was never happy with the stamper since every once in a while it would print garbage.
If you do not have that spring, I don't know what one would do....Maybe the spring is just inside hanging around...I guess I was lucky that I kept the one I found.
No spring...send back to DYMO for repair.
Good Luck.
Nov 23, 2010 | Dymo DateMark Date/Time Stamper
How to make print date?
this site will solve ur problem www.worldstart.com/tips/tips.php/642
Dec 03, 2009 | Dymo DateMark Date/Time Stamper
How does it print? (Datemark) Some magical way?
Hi Patricia,
First, try doing sequence power cycle by turning off the printer, computer and the router (if you're using one attached to your system) to make sure everything works perfectly in the printing process. Moreover, you may try to open the back cover where the batteries are and press the pinter reset button to refresh the printer settings. best regards, Jazerblue
Aug 24, 2009 | Dymo DateMark Date/Time Stamper
P reset keeps flashing and won't print
Open the battery compartment and use a paperclip to push the printer reset button
Jun 30, 2009 | Dymo DateMark Date/Time Stamper
Date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Jun 18, 2009 | Dymo DateMark Date/Time Stamper
It prints different from display screen
What prints different?
What Display Screen?
What are talking about?
Buckup
full details gets the answer
I know about computers
I am not into mind reading
Assuming you have one that is?
Oct 20, 2008 | Dymo DateMark Date/Time Stamper
The Datemark will not print the time, only the date shows.
Please try going to Dymo's site at http://www.dymo.com/media/UserGuides/Time%20Manual.pdf I also had trouble finding the instruction book/owner's manual.
Apr 04, 2008 | Dymo DateMark Date/Time Stamper
My Dymo DateMark won't print.
Feb 20, 2008 | Dymo DateMark Date/Time Stamper
Dymo DateMark stamper doesn't print.
if it is an older model [2001 or so] you just gently put your hand over the top like your going to pick it up but just push down and slightly forward. there is a button on the underside.
Jan 25, 2008 | Dymo DateMark Date/Time Stamper
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
