Question about Ovens
I need to now what prongs to plug into the oven switch
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 32 Answers
What kind of oven it that for??
Posted on Nov 24, 2012
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
Oven locked with door open how do I reset it?
my first thought is if the oven is standard 220 three or four prong electric, for safety, go to breaker switch panel,"in House or outside of house", open pannel door and find the breaker switch marked for "oven" or "kitchen utility" . it will be a double switch of 20 to 25 amp ,"each". or it will b One breaker switch of 45-50 amp. ,switch it to off. then see that the oven has no power, the stove top as well as the lights and the oven .try to unlock it now. by lever or button ? then if not unlocking turn the breaker back on and try it again. hope it works for you.
Mar 29, 2015 | Ovens
Half of the element of my range stopped working. How to diagnose or fix a short-circuit?
OK 1 D/C the power to stove. 2 get an olms meter and remove the burners, 3 Put one test wire on the wire to elements wiring other end to plug. . turn on burner switch and see if you get 0 ohms reading if so good cercert. if not bad. move the test lead to each of the 3 plug prongs. before you move to the next wire to the element./ You trace them all you will find your short. also inspect all wire for brakes that could be touching metal. Hope this helps mike
Nov 19, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
I just bought a new whirlpool stove and it had a 4 prong plug and my outlet only has three can i just switch the plug
Jeff Hi where are you located ? that almost sounds like a stove from over seas ?
I can't understand why you would have a plug like this on a GAS type stove ? give me some more infomation
Dec 03, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I HAVE A FRIGIDAIRE GALLERY RANGE WITH A 3 PRONG, BUT NEED A 4 PRONG, WHAT DO I DO?
You can go out and get four prong plug and wire according to the directions on the web site below.
If you feel this has been helpful please give me a comment...Thanks!...Jim
http://www.appliance-repair-it.com/range-cord.html
Feb 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Power feed in 208vac-1phase, is this a true single phase 208 & neutral or 2 120vac feeds 1 on Z and 1 on X ?
208 is usually referred to as a singe phase but technically it is poly phase. The industry refers to it as single phase as it is uses one line as power and the other as "Common", not neutral. If the plug has 3 prongs, It is 2 lines of power and an earth ground. If the plug has 4 prongs, It is 2 lines of power, one neutral, and one earth ground. Let me know if you need more.
Dec 18, 2010 | Garland MCOE5 Electric Single Oven
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 | Ovens
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
3 wires black white ground from box from oven red black white ground what goes where
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
Aug 17, 2009 | Frigidaire (FEB30S7D) Oven
Ovens Logo
96 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
