Question about Konica Minolta Bizhub C550 Color Copier/printer/scanner
Message says "part indicated by arrow is open"
There is no arrow showing and messaage will not clear. I have tried turning off and on
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
Why cant i send and recieve messages?
Make sure that your data connection is active.
Aug 19, 2014 | Nokia Cell Phones
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
How to clear back to factory setting
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
When you press the on key it flashes on but does not stay on
Hi calcu,
The process below should reset your calculator.
Please be prepared to re-install the calculator's OS if you run through this process.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    reinsert the AAA battery and then turn the calculator on. The calculator should display the
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. Goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the process and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Dec 29, 2010 | Texas Instruments TI-84 Plus Calculator
Panasonic KX-T7630 the red light is on all the time as if i've got a messaage but there is no message. Nothing I do will turn the red light off.
Wow. Works for me. Try pressing MESSAGE and look at the display. The 3rd soft key will say "CLEAR". Keep pressing MESSAGE and CLEAR until the messages are empty.
Carl
Nov 04, 2010 | Panasonic KX-T7630 Corded Phone
The VM is lit on my phone all the time even though i have no messages, how can i clear this?
if the phone is an AAstra phone model 9116 (look on the underneith) then hit Options then down arrow (under the viewer) to the indicator message then hit delete and then save
if it is a 9216 or 9316 model then slide the little bar(under the view glass to the right and hit the button under the slide and down arrow to option 4 and hit the 4 button and turn of the indicator. it will work properly imediately and resume as it should..
to prevent this , after you listen to your messages hit the * button twice before you exit your voicemail system
Jan 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
Brother printer ink tanks not resettinmg to full when refilled When ink tanks are refilled and replaced the printer is still showing empty tanks and still printing in a green colour
I had the same problem;
Try this
1. Turn the printer off (push off button)
2. Open cover and remove all the ink cartridges. Just out of the clip will be sufficient
3 With cover still open, Turn printer on again (push on button)
Message should come up to replace all the ink cartridges ( in sequence probably). Follow the instructions
4. When all the cartridges have been replaced it will prompt you to close the cover.
5. Close the cover and it will ask if you've replaced each of the cartridges one by one
6 Use the up arrow (Menu,up arrow, down arrow, set) to indicate 'yes' for each one.
The printer will then do a clean cycle and everything should be ok from here
Good luck
Nov 09, 2009 | Brother DCP 115C All-In-One InkJet Printer
Ink system failure error 0xc18a0101
I had this problem, was about to buy me a new printer but than found the perfect solution. Just excuse my english (I am German). I have to translate the menue German into English and I hope I do it right.
Push the Setup and the arrow that shows to the left at the same time! Than push ok. A menue opens that says something with support. Push the arrow right button until system configuration appears. open it with the OK button. Now it should show the hardware failure status. If not look for it with the arrow button. When found the hardware failure status, again push OK button. Than something like clear inquiry should appear, push OK. As soon as the "hardware failure status cleared" appears, you can leave the menue by disconnecting the printer from the powercable.
Reconnect it with the powercable and it should work again.
Aug 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Konica Minolta Bizhub C550 Color Copier/printer/scanner Logo
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
