Question about Homelite Models 350 Hg Sl Chainsaw Parts List Manual
I have old Homelite 350 chainsaw. What spark plug does it require so i can purchase spare. Thanks, Scott.
  • 597 Answers
SOURCE: Homelite 14inch chainsaw
Open the gas tank then reach something inside the tank. You will feel a small fuel line in there. Try to fish out the loose end of the line and you'll find a fuel filter on the end of it. Clean it or replace it and then try to start it again.
Posted on Sep 13, 2009
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
dontbother10
  • 2220 Answers
SOURCE: homelite model 245 chainsaw won't start after sitting 1 year
Please test for spark and reply below with what you find. I think bad ignition or wiring. This checks the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 11, 2010
  • 4088 Answers
SOURCE: homelite ranger 33cc chainsaw will not start.
Did you check for spark when the plug was out? It should be blue and snappy. If not, you need to expose the flywheel assembly by removing the left case cover, then remove the stop switch wire from the ignition module. If now sparks, check the stop switch and connecting wire for grounding. If still no spark, replace the ignition module. Use a thin businees card for a gap gauge--turn the magnets under the module, insert the card into the gaps, then loosen the mounting screws and let the module stick to the magnets. Tighten the screws and rotate the flywheel to remove the card, then turn the flywheel one full rotation and check that the gap doesn't close up at any point. If the original test had good spark, then pour some fuel mix into the plug hole and attempt start--if you get several pops, then check the fuel system. Start with checking the fuel filter which will commonly plug up over time and check the fuel lines for decay or damage. Does the primer button pull fuel into it when pumped several times? Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and trouble shooting. Note carefully the items within the lower chamber as they are critical to proper running. Hope this helps!
Posted on Jun 17, 2010
  • 3 Answers
SOURCE: homelite ut10560 chainsaw good compression, good
check your fuel lines for cracks carb screen (if it has one) or jets might be clogged , also, I have a husk 350, fired only with gas in the carb, would not run at all just start and off. would not fire at all without doing that. the head bolts were little lose. I tightened them down put it back together, and that was the problem.
Posted on Jul 07, 2010
What is a replacement spark plug for the Homelite DJ168F-18500A plug provided with this unit?
HOMELITE DJ168F-18500-A - SPARK PLUG - Part Number ...
www.smallenginesprodealer.com/homelite/.../homelite-dj168f-18500-a-spa...
HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ... This is an original approved HOMELITE replacement part.
A100643 - SPARK PLUG - Part # A100643 - Small Engines ...
www.smallenginesprodealer.com/homelite/.../a100643-spark-plug-part-a...
This is an original approved HOMELITE replacement part. ... HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ...
HOMELITE GM304012 - SPARK PLUG A - Part Number ...
Jan 18, 2016 | Homelite Garden
Homelite xl12 chainsaw
try a new spark plug
Dec 20, 2015 | Homelite Garden
I have homelite textorn 7500watt generator not strating ,no carunt to spark plug
You'll need to look up to see what the ohms are on the coil of that chainsaw use of a multimeter required it should have a reading between to set readings if ok then check for loose or broken wires
Feb 07, 2015 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Chainsaw will only run with choke on and cant get it to idle back
there is a jet inside the carb that is plugged up leaning it out
Aug 18, 2012 | RTO Spur Sprocket For Stihl 017, 021...
This homelite chainsaw is bran new
Remove the spark plug and check for blue and snappy spark. If weak or nothing, try another spark plug. If still improper spark, return the machine for replacement under warranty. Make sure you have followed all instructions for re-start. Good luck!
May 24, 2010 | Homelite ZR10926 16 Chain Saw
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Cannoy start saw. purchased reconditioned saw this
Make sure you have spark to the plug, make sure the plug is clean and dry,squirt some starting fluid into the plug hole and put the plug back in and try it. If it fires and then quits you probably have a fuel problem
Aug 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Feb 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Models 350 Hg Sl Chainsaw Parts List Manual Logo
22 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
