Question about Sharper Image Ec-ws115
Adjusting display brightness - Sharper Image Ec-ws115
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
IT-800-EC-35. How do I brighten the screen?
Adjusting Display Brightness You can use the following procedures to adjust display brightness to make it easier to
read under different lighting conditions.
Press the "Fn" key and then press the "5" key or "6" key after con? rming that "F"
is displayed in the lower right corner of the screen. Pressing the "5" key adjusts
brightness for a darker display, while pressing the "6" key adjusts brightness for a
lighter display.
In order to continue to make adjustments, press the "5" key or "6" key again after
? rst pressing the "Fn" key.
Brightness settings can also be made by navigating to the menus and tab in order of
Start ? Settings ? System ? Backlight.
The manual is here:
Casio IT 800 Series User Manual
Aug 04, 2015 | Casio Computers & Internet
Screen brightness
Changing the Screen Brightness
1. Press the Home Key > Menu Key > System
settings > Display > Brightness.
2. Check the Automatic brightness box to make the
phone adjust the screen brightness automatically
or clear the check box to adjust the brightness
manually.
3. Tap OK
Mar 10, 2014 | Tracfone Wireless ZTE Valet
Adjust brightness ipad
that is a basic thing to know:
  • Open Settings and tap on "Brightness & Wallpaper"
  • Adjust the brightness slider as desired
  • Flip "Auto-Brightness" to OFF to have the screen stop automatically adjusting brightness
adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-0.jpg adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-2.jpg Change Screen Brightness Stop the Display Auto Adjusting on iPhone
Jul 25, 2013 | Apple iPad Tablets & eReaders
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
The brightness function keys stop working, and the screen is at full brightness all the time.
you can adjust brightness display driver property r click property display setting advanced
Feb 11, 2011 | HP G62144DX Laptop
How to increase a brightness of screen
I assume you are using windows. Follow these steps to adjust the screens brightness:
- Go to the Control Panel - Go to display - On the left pane click adjust screen brightness - At the bottom of the screen you should see the screen brightness meter being displayed. Change it accordingly and then apply the settings to keep them.
Alternatively you should be able to adjust the brightness of your screen using the a combination of keys on your keyboard. This differs with the type of machine though
Jan 19, 2011 | Computers & Internet
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Dec 22, 2007 | Dell Inspiron 9400 Notebook
Sharper Image Ec-ws115 Logo
51 people viewed this question
Top Sharper Image Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Sharper Image Measuring Tool and Sensor Expert? Answer questions, earn points and help others
