Question about Gateway MX6453 Notebook
It looks like my fan is going out
I have a Gateway MA3 aka MX6453. The problem that I am experiencing iswith the computer freezing up. It appears to be related tooverheating. I tested this by opening up the back and booting it up. After about 5 min. the computer freezes (mouse won't move, nothingfunctions short of powering down). I blew canned air on the fan andthe computer immediately un-froze and continued to run for about 5 min.until freezing again. I spun the fan with my finger and it began to runon it's own and the computer immediately began to function again for aperiod of time. Looks to me that the fan has a problem and it isshutting down when it gets too hot. Is this something that can beeasily repaired without taking it to the shop, and what needs to bereplaced? Part source?
  • asasworld Jan 05, 2009
    This is a Gateway laptop. There is only one fan in it. It is a cooling fan which is mounted near the side of the laptop and has attached to it, two copper heat tubes that are about 6 in. in length. The copper tubes are attached to the center of the board and run around to the fan.
  • errin durham
    errin durham May 11, 2010
    first of all what kind of fan is it there are programs on the web that can help you monitor your comp temps one of the is called everest home edition. what is the fan covering? and if it is the fan you can get them of variuse sites for anywere from 4$-15$ and you simply just plug them in and attatch them but it all depends on what fan it is if possible please clarify more to dragon_rage27@att.blackberry.net pics would also make it easier...thanks and good luck
    Problem Solver:
  • 9 Answers
Ok well than it is the fan if there is only one but bad news is the fan will cost you around 30 dollars here is a good site that i use frequently http://www.priorityelectronics.com/gateway/laptopfans.htm
it should be preatty easy to install but if you have anymore questions please dont hesitate to ask
Thanks=)
Posted on Jan 06, 2009
  • errin durham
    errin durham Jan 06, 2009
    o and also try to not use the laptop untill it is fixed else you risk damaging it beyond repair
I have all screws out of back of gateway ma3 all tabs are clear on top of key pad but wont come out
The only things you could hope to upgrade in a laptop that old is the RAM and the hard drive. if it's an x86 computer the most you get get is 4GBs of ram and maybe a 250GB IDE drive in that. Laptop's are not really meant for upgrading. It isn't cost effective to upgrade laptops anyways. Spend $300 on a new low end laptop and you will have something at least twice as powerful as this laptop you currently have.
Dec 16, 2011 | Gateway MX6453 Notebook
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
Gateway MX6453 fan does not start until 70 degress celsius
This would be due to a faulty sensor if it does not reboot and overheat then leave it be and buy a cpu cooler that goes underneathe the unit there around 20 bucks.
Jun 14, 2009 | Gateway MX6453 Notebook
How to open case for an mx6453 gateway laptop
Detailed post with photos. Same problem, different model; but it looks the same and other users said it worked for them. Read all the user comments first to see where other people had problems and maybe messed their computer up worse.
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Also, check these two sites for gateway's info on how to remove the keyboard:
http://support.gateway.com/s/Mobile/Q106/Blade/8511369.pdf
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Mar 29, 2009 | Gateway MX6453 Notebook
Gateway MX6453 power pin problem
http://shop.ebay.com/items/?_nkw=Gateway+MX6453+dc+power+jack
Any of those should be fine.
Mar 24, 2009 | Gateway MX6453 Notebook
Disassemble Gateway MA3?
http://support.gateway.com/s/Manuals/Mobile/8511180.pdf
heres the service manual
you need a PDF viewer (fox it reader or Adobe PDF Reader) to read this.
Feb 01, 2009 | Gateway MX6453 Notebook
Gateway mx6453 won't start up
I would say that the problem is with the video card, and yes, you may need to replace entire mainboard. Check your warranty period, if it is still valid, just go to service center to get it fix, no need to ask around.
When replacing mainboard, your files, softwares and settings is still in place. Unless you also replace the hard drive, you will have the computer back as is used to.
Jan 10, 2009 | Gateway MX6453 Notebook
Gateway MX6453 or MA3
Because the power jack is soldered directly to the motherboard, side to side stress on the plug over time damages more than the solder joint, it also loosens the little copper sleeve that lines the hole in the motherboard. Simply resoldering the joint only cures the problem for a month or so. You must remove the plug, wrap and then solder a thin piece of wire clipped from a small resisitor lead to the base of the center pin connector leg (the one to the back of the jack) and pull through the board with the leg. Then the extra wire is bent over like a hook and coiled around the spot -- squashed flat. then the coiled extra wire acts as an added anchor when soldered (hooking the power jack connector to the board.) this joint will survive like or even better than new. Not doing this added step gaurantees you joint repair will fail not long after it is made.
Jul 23, 2008 | Computers & Internet
Gateway MX6453 Notebook Logo
176 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
