Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
LID TO STACKABLE TOP LOAD WHIRLPOOL WASHER WILL NOT STAY UP IN OPEN POSITION
jsrock516
  • 5911 Answers
SOURCE: Washer won't spin and drain water (does everything else)
If you are talking about a small plastic piece that is on the washer lid that pushes down on the lid switch when the lid is closed, it called a "lid strike". This is an easy fix and does not require opening the washer. If, however, the lid switch itself (which is mounted under the washer tub rim) is damaged you can replace it by following these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Replacement parts can be found at searspartsdirect.com or repairclinic.com. Simply type in your COMPLETE model number (located along the opening of the tub rim under the lid) in the Search Index. A parts index with illustrations and prices is available.
Good Luck and I hope this helps you. Post back if you have any further comments/questions.
Posted on Feb 25, 2008
mikedurland
  • 481 Answers
SOURCE: How do you open the
you have to take the case off. take out the two screws on the control panel. they should be on the base of either the front or the back of the control panel. the picture is of one that is in the back. e23f106.jpg
these clips release the entire case, so you will have full access to everything you want including the lid switch.
Posted on Aug 07, 2008
ghappliances
  • 126 Answers
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 113 Answers
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
Posted on Dec 16, 2008
jmgldsmth
  • 2005 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
Lid locked & will not open. What to do?
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler Kenmore Whirlpool top load washer. lid lock issues ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my similar ...
Oct 12, 2015 | Kenmore Washing Machines
Frigidaire top load washer lid will not stay in open position.
front of washer legs are to High or back legs to low level machine or change door hinge
Aug 13, 2013 | Frigidaire Affinity ATF7000E Front Load...
My problem is the washer won't drain or spin. i saw the solutions and sounds like my problem is the lid switch but it leads to another problem. what and where is the lid switch.
where the lid switch is on the top-back of the washer near the water inlet. you must open the cover. lid position switch associated with the hinge lid-open lid. you must open the screw from the cover. Pull up on the cover, after being released you can find where the lid switch, the location was near the water level sensor. can be used to manually switch, or a light sensor, located under the cover of your washing machine. Hopefully help
Oct 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
try unplugging from the power and starting again
Jul 30, 2008 | LG WM2077CW Laundry XL Front Load...
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Whirlpool Top loader
Open the lid and the model and serial tag is on the washer itself in the middle under lid in back. Open lid and look at area where lid and washer top come together between hinges.
Nov 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Disassembly
what are u trying to repair on it?
Aug 20, 2007 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
315 people viewed this question
Dan Webster
Dan Webster
Sal De
